Cragar SS wheels with adapters.....
Old Apr 19, 2005 | 11:57 PM
vetteguy75's Avatar
vetteguy75
LA Events Coordinator
Default Cragar SS wheels with adapters.....
OK, on Monday I purchased a set of Cragar SS Chrome wheels (15x8) with 4.25" backspace...I will received them on Thursday from JEGS. To make sure the wheel clears the caliper, I also purchased a set of billet aluminum 1" wheel adapters ...not spacers but bolt on adapters with the same bolt pattern from VPS. I measured the backspace on the stock wheels= 4". Based on the info for the new wheels & adapter, I calculate a .75" increase in the placement of the tire from it's stock location (4.25" backspace less 1" adapter less the 4" stock location)....does this make any sense?? am I correct in the calculations? If so, will it rub the inside fender? or rub anything else? Any help or opinon will be greatly appreciated!
Old Apr 20, 2005 | 07:58 AM
Tele_Man's Avatar
Tele_Man
Geez, you're making it seem awfully complicated. I just put an aluminum spacer behind the wheel thick enough to clear the brake caliper. Works fine. Haven't had a bit of trouble.
Old Apr 20, 2005 | 08:18 AM
bobs77vet's Avatar
bobs77vet
From: Arlington Va Current ride 04 vert, previous vettes: 69 vert, 77 resto mod
you could always mount one wheel and move it around the car to see....what size are the tires? I can't imagine having a problem with 225s anything bigger though i'm not sure of.
Old Apr 20, 2005 | 09:24 AM
vetteguy75's Avatar
vetteguy75
They are 255's
To Cragar SS wheels with adapters.....
