Body Mount Torque Specs
Old Apr 20, 2005 | 03:14 PM
IRON WILL's Avatar
IRON WILL
Default Body Mount Torque Specs
Does anyone know the proper torque specs for polyurethane body mounts on a 1980 corvette? I can't find it anywhere. I have my assembly manual for a 69 Olds Cutlass that says its 50ft-lbs, but thats a completely different car. I would appreciate any help thanks.
Old Apr 20, 2005 | 04:18 PM
Chumpzilla's Avatar
Chumpzilla
Old Apr 20, 2005 | 11:30 PM
tigers123's Avatar
tigers123
Default torque specs
http://dodgeram.org/tech/specs/bolts/SAE_bolts.html Pay attention to the grade of bolt as well as the diameter
Old Apr 21, 2005 | 12:37 AM
Jclgodale3's Avatar
Jclgodale3
Is that a realistic table? Considering there is a fairly flexible center section (the mount) being squeezed between? I could see those values if it was steel to steel.
Old Apr 21, 2005 | 09:39 AM
noskillz's Avatar
noskillz
I have a 69 so the spacers are solid aluminum. The torque is listed at 40 - 50 Lbs Ft. Not sure what the rubber spacer torque would be...
Old Apr 21, 2005 | 10:48 AM
NHvette's Avatar
NHvette
The poly mounts should have a steel spacer that slides through the
center of the poly mounts. The bolt clamps down on the spacer, not
the cushions. Check it out - and see what I mean. The cushions are
only compressed as far as the spacer. Use normal torque for that bolt
diameter ... 7/16" coarse I think.
I don't have a picture of the spacer, but here is a mount that is torqued
down for reference:
http://nhvette.homeunix.com/ftp/in/polymount_small.jpg
For the #1s you can go full torque for grade 8 (assuming you are using
grade 8). However, I'm not confident that the stock cage nuts are very
hard, so I'd limit the cage nut mounts to 50 ftlb max.
Ah-hah: Just found it in my 75 AIM ... section 1B pg 2: 40-50 FTLBs.
To Body Mount Torque Specs
