line lock switch
Old Apr 21, 2005 | 10:40 AM
jerome1979's Avatar
jerome1979
Default line lock switch
i want to instal a line lock, i know that is esay but i don't have any idea about witch switch to use !? (i will instal it to block rear brake pressure)
any feedback about your own installation!?
Old Apr 21, 2005 | 12:22 PM
tabbruzz's Avatar
tabbruzz
I just installed one that I purchased from Summit. It was there brand(comes with switch and light. and I also bought the install kit which comes with brake line\fittings and such. I think the total cost was under $120.00....Tony
Old Apr 21, 2005 | 12:29 PM
406shark's Avatar
406shark
First and foremost it needs to be a momentary contact switch.
I have a coiled cord on mine that is run up where the e-brake handle is. I have the last 6-8" of the cord covered with a piece of hose with the button coming out the end. It allows me to pull up on the wire/hose to access the switch, but tuck it down when not needed.
Good luck,
Jeff
Old Apr 21, 2005 | 12:30 PM
toddalin's Avatar
toddalin
Rear Brake pressure??? I use my line lock to hold the Front Brakes for burn-outs and stops on steep inclines (hill holder).
To line lock switch
