converting to lt1 tpf
Old Apr 21, 2005 | 08:43 PM
dalej's Avatar
dalej
5th Gear
Default converting to lt1 tpf
I am putting an lt1 tpf into my 76 stingray and i have all the wiring and comp. just wandering where i might be able to find a diagram to easy the frustration of chasing wires..
Old Apr 22, 2005 | 03:13 PM
markdtn's Avatar
markdtn
If you buy a new harness it will be marked what goes where. If you buy a used aftermarket harness, the maker might help you.
If you have the donor cars harness, you need the shop manual for that car and for your car. You can get them from Helm Inc., Ebay, Swap meet, etc. Corvette manuals are available through the usual Vette catalogs. Also exploded-view vette wiring diagrams are available through the catalogs. There are not too many wires to deal with actually. Regardless, you will probably have to have your PCM worked on by Howell, Street&Performance, or one of the others to remove EGR, VATS, or any other systems you won't be using.
Old Apr 22, 2005 | 03:14 PM
markdtn's Avatar
markdtn
Check out www.corvettefaq.com for more swaps.
Old Apr 22, 2005 | 03:17 PM
markdtn's Avatar
markdtn
See also http://forums.corvetteforum.com/show...398&forum_id=3
Old Apr 22, 2005 | 07:00 PM
dalej's Avatar
dalej
5th Gear
cool thanks. I am gonna have to get a book rather than just play it by ear
Old Apr 26, 2005 | 08:45 PM
dalej's Avatar
dalej
5th Gear
got all wiring figured and finished now comes the fuel pump and there will be life (at least I hope)
To converting to lt1 tpf
