ac change over
Old Apr 22, 2005 | 01:06 AM
terry82's Avatar
terry82
Default ac change over
i seen a 134a change over kit at napa .it has the 134a charge and a fluid that makes the oil that is in there compatible with new 134a . plus the new valves .anyone try this kit .
Old Apr 22, 2005 | 03:47 AM
djcwardog's Avatar
djcwardog
Yep. I used a kit like that. I swapped out all the O-rings and I used a 90° fitting on the VIR (a 1973) so I could add Freon easier. Be sure your hoses, etc. are good and will hold the seal.
Old Apr 22, 2005 | 07:26 AM
cosmicvette's Avatar
cosmicvette
where do I find out more about this kit?
Is there a website?
thanks for any help.
cosmicvette
Old Apr 22, 2005 | 07:50 AM
PhotoVette1's Avatar
PhotoVette1
"...and I used a 90° fitting on the VIR..."
Duh! I used to be a ultra-cold refrigeration technician and designer, so why didn't I think of that?! It'll make things so much easier! Thanks!
I charge my system (1977 EEVIR) with R409a. It's compatable with the existing oil (for R-12--both use POE)--dump the R-12, pull a vacuum, and add the R409a. I've been using it for 3 years.
I have glass tops and (yesterday for instance) I had 42F air coming out of the vents--it was 85F outside and in the direct, midday sun. Needless to say, the cabin temperature was frosty.
Old Apr 22, 2005 | 09:02 AM
ICEMAN59's Avatar
ICEMAN59
I am currently an industrial refrigeration mechanic, and I work for myself. I work on Ammonia systems, Natural gas, all the Halocarbons and Florocarbons (Freon). I converted mine to Hot Shot which is 409B I think but I would check that there are so many it's hard to keep track, I have a chart in my truck but it's not here. It worked great, before it barley cooled and I have a brand new compressor, accumulator, orafice tube, evaporator, and spal fans. Now it will freeze your nu*s off.
I forgot to mention it is a direct drop in, no oil change, orafice change, just evacuate system and charge with Hot Shot, be sure and turn the drum or can upside down to charge liquid, it is a teranary blend and if you charge gas you may not get the right chemical compositon. When charging liquid, barely crack your gauges like 10 to 15 psi above the operating suction pressure, you don't want to slug the compressor with liquid.
Old Apr 22, 2005 | 10:05 AM
PhotoVette1
Hot Shot is R414b. It works extremely well with oriface type, but not so well in the VIR type of system--I tried both.
Old Apr 22, 2005 | 01:15 PM
terry82's Avatar
terry82
Is there a website?
cosmicvette
go to napa its on the shelf
Old Apr 22, 2005 | 07:39 PM
82Vette'ster's Avatar
82Vette'ster
My 82 (oriface type) was "converted" by the previous owner, so I'm suspecting R134a? I've heard that in general that it won't cool as well. Will changing over to Hot Shot (R414b) or something else give me a better chance of getting decent cooling. Note: Phoenix, Arizona with glass T-tops, present system doesn't cut it.
What would be needed to change from 134a to R414b?
Old May 18, 2005 | 09:53 PM
71VETTEWI's Avatar
71VETTEWI
Default Vir?
What is the difference between a VIR and an Orfice? I am thinking of installing a factory air box in mine with a newer style Compressor? What sort of advise do you guys have as I am starting from scratch. I have a 1975 unit to put in my 71 W/O Factory Air. I was going to get one of the new serpertine belts set ups from Summit that includes an A/C compressor.
Any advise?
Thanks,
Charlie
To ac change over
