Body Removal
Old Apr 24, 2005 | 09:39 AM
canadiansmitty's Avatar
canadiansmitty
1st Gear
Default Body Removal
Hello, i am hoping that you guys may be able to help me. My buddy has an 80 with T-tops and he has noticed his frame is rusted/cracked. He just bought a house so he has a place & the time to take the car apart to fix it. The car is in VERY good shape so he was hoping to just lift the body off, fix the frame & put it back together. What we are wondering is it possible to remove the body without taking everything out of it ? dismantle as little as possible lift it, fix it, drop it back down & then go cruising. Is ther some sort of hoist we can hook/build into the garage ceiling to lift it off ?
Thanks for any help/advice
Steve.
Old Apr 24, 2005 | 10:03 AM
Bluewasp's Avatar
Bluewasp
NoVa Events Coordinator
St. Jude Donor '14
I helped take a body off an 1980 and I'm going to take the body off my 1980 in a few weeks.
We left the interior in the car, removed the bumpers, disconnected the steering, shifter, cables in engine bay that go into the firewall, gas tank filler, body mount bolts... that's all I can think of now.
Make sure to support the whole body. The front can break off as you lift the body off.
We lifted the body off with 6 people. We had two other people looking under the body to see what needed to disconnected as we lifted. It was a long process of lifting, disconnecting, and lifting again....
Old Apr 24, 2005 | 03:47 PM
tigers123's Avatar
tigers123
Default seat bolts
Depending on what year it is, doesn't one of the rear seat bolts have access through the frame? I don't know if the nut grips the frame or not, but I believe I would look into that before I started lifting.
Old Apr 24, 2005 | 07:46 PM
redwingvette's Avatar
redwingvette
I lifted the body off my 73. See if this helps at all:Body-Off
Old Apr 24, 2005 | 08:38 PM
cannonfl's Avatar
cannonfl
I lifted a 68 vert...
Mine had a wire cable connecting the body to the frame right above the drive shaft and in front of the differential ( near the seat belt bolt locations ). It was covered in grease and hard to find.
Old Apr 24, 2005 | 09:41 PM
72LS1Vette's Avatar
72LS1Vette
If the frame is that bad you guys should look very carefully at the birdcage when the body is off. Windshield frame, rocker channels, body mounts, floor pans are a few of the areas that might be in as bad shape as the frame. Anything can be fixed given enough time and $ but the cruising part might be delayed by a few years.
Rick B.
Old Apr 25, 2005 | 12:30 PM
cannonfl's Avatar
cannonfl
My rocker channels had a lot of rust in the same area as the frame. The rest of the bird cage looks
Old Apr 25, 2005 | 02:11 PM
Bluewasp's Avatar
Bluewasp
St. Jude Donor '14
80s have that as well. I remember that one very well now...
Old Apr 25, 2005 | 02:12 PM
Bluewasp's Avatar
Bluewasp
St. Jude Donor '14
"bird cage"?? Which part is that?
Old Apr 25, 2005 | 02:32 PM
redwingvette
The steel frame work inside the fiberglass around the passenger compartment. Bird cage
Old Apr 25, 2005 | 08:16 PM
steves_77vette's Avatar
steves_77vette
Here's my blog on my frame off restoration. Check the notes for January to see how to get the body off and how I did it. I went the hoist and frame approach.
http://77vette.blogspot.com/
To Body Removal
