Rewired my headlights
I bought 2 bosch 30 amp relays for $5.95 each and two 30 amp fuses.
I mounted the relays in the left hand corner near the actuator for the left headlight.
I opened up the wire harness and the low beam is the tan/light brown wire. I cut this and used it to trigger the low beam relay. I cut the green to trigger the high beam relay.
Now my head light switch and dimmer switch instead of handling 20 amps now handle less then an amp. They should last forever and at the same time my voltage to the lights should be up about 2 volts, making for a brighter light.
The hood has to come off to do this.
This is a close up of the relays and fuses.
This is where I mounted it so it was close to the wiring harness and easy to splice into the existing harness without long extensions
What great timing. I am going to do this while I have the parts out for the frame work. One question, where did you run the power from?
I just got four new sealed halogen beams, and I expect the lighting to be much improved with this new wiring. I was planning on using the central power distribution point as MAD Enterprises suggests.
Have you had a chance to turn them on and see the difference?
Ken
Ken
Sure I turned them on alot but only in the shop in the daylight, not outside, not with the motor running and no test driving. The weather is bad, improving thou and I expect to take the car out this comming weekend.
I just like the idea that all lighting power doesn't come through the fuse block and the headlight switch. I have relays for my lights, my fuel pumps and my fans and all this power comes direclty from the battery and not through the fuse panel. All relays are fused properly. Under the dash power is very minimal.'
I also have a alternator output of about 14 volts and this is what the lightling should see.
get an American brand....
maybe some junkyard relays from fan controllers, GM, FORD, etc....or the replacements....if it has Lucas or Bosch on it, it's junk....
GENE
When I bought my car there was a white dust inside the speedo and tach. Well when I tore into it I found out this was from a fire extiguisher. The headlight switch had melted down at sometime in the past. It must have also ruined the plug to the headlight switch, as bubba had used lamp cord to repair the missing plug. Now tell me how safe was that. It was put together using ceiling fan wire nuts on a few and and just twisted together with duct tape insulating the other part. I for one am for this type of mod. Look at the point where the headlight switch should be. The outside of the pad is fine.
By the way anyone want to buy a drivers side dash pad, cheap?
I'm being out lumened by every car on the road. I can barely see 60 foot ahead with the low beams on.
The other idea is use high beams in the low beam position. I would just rewire a high beam plug on.
I need to get more light.
And no George i don't want to use airplane landing lights. I want something i can pick up at any parts store or gas station. You have to be carefull about those powerfull lights overloading the circuit. I used to have some high intensity lights that caused the circuit to trip every time i hit the brights and left them on for more than 10 seconds.
I have faith in relays and if they ever cause a problem it is easy to change one out for another. I always always run relays instead of switches. The switches are only used as triggers for the relays.
I really tried to find a wiring harness for the relays but had no luck so I made my own with spade connectors, soldered everything and used heat shrink tubing over the entire connection.
Norval: You can get the real bosch relays for $1.99 as well as the sockets from partsexpress.
http://www.madelectrical.com/catalog/rly-1.shtml
When I recently wired my fans, I took your approach and did my own connectors. I have the headlight relay upgrade on my (long!) to-do list...I don't want to pull the hood though! I'll find a place to mount the relays that's a bit more accessible
Edit: I just looked at partsexpress as suggested above, and you can get the same goodies MUCH cheaper! :
http://www.partsexpress.com/webpage....7&WebPage_ID=3
a friend's Jeep 4.0 DPFI had a fire in it's past, full of Bosch type relays, the wiring is a nitemare as a result, and I noted the stock Jeeps of the era were full of the same, and that is the area of the fire....
Wife's Escort lost the a/c compressor clutch engage function....went through it, engine controll module...full of relays on a PC board, inside a metal can rivited together....250 bux Ford only....made by Bosch, stamped on the can.....pulled it apart, smoked relay, burnt board, so I hardwired in a 4x rated relay, and a/c now works fine....
Sorry, but over the decades, I have learned that european electricals are most allways sub-standard, the Japanese learned quickly though, and eliminated most of their sub standard electrical problems....
As for GM using Bosch, I"m unaware, maybe, and certainly there are bad fan relays there, I use the black rectangular things, seem fine, the more modern oval/rounded case relays seem to burn up a LOT and take the plug in with them....figgers....
GENE
GENE
Grinchia that is a great informative link. Thanks.
If it's american it's not necissarily better
As for tripping relays that is the good thing about this conversion. You can not possible overload the circuit. I have the potential for 60 amps output before the relays/fuses are overloaded.
Again the big thing is the increased voltage and the headlight switch/dimmer switch never see more then an amp or two, just the triggering current for the relays.
Ken
