4 speed shifter problem
Old Apr 26, 2005 | 01:23 AM
Airfix's Avatar
Airfix
Default 4 speed shifter problem
The shifter on my '72 4 speed sometimes get stuck between reverse and 1st when going into reverse to get the keys out.
When it's stuck the transmission is actually in 1st but the shifter appears to be closer to reverse. I have to lay on the ground and shake the shifter rods to clear this problem.
Any idea as to whether this is a linkage problem or something more serious internal to the transmission?
Any ideas appreciated.
72 350/4spd
Old Apr 26, 2005 | 01:36 AM
GDaina's Avatar
GDaina
I bet the shifting arms are not lined up, easy enough to adjust...if you have a service manual, the procedure is explained...if you don't have one, let me know, I'll type it out.
Old Apr 26, 2005 | 01:50 AM
Airfix's Avatar
Airfix
Thanks,
Iv'e got the Haynes manual, I'll take a look.
To 4 speed shifter problem
