Bottomless Brake Pedal
Old Apr 26, 2005 | 11:59 AM
nickc377's Avatar
nickc377
Default Bottomless Brake Pedal
I have a 1973 and to stop it, the pedal goes all the way to the floor. It still stops nice so I think the calpers/pistons are good. The pads and rotors are fairly new. Any ideas?
Old Apr 26, 2005 | 12:04 PM
BKbroiler's Avatar
BKbroiler
Either air in the system or a bad master cylinder.
Old Apr 26, 2005 | 12:17 PM
82XFire's Avatar
82XFire
If it stops nice and straight (no pulling), I'd say MC, if it's a dancin', bleed it out thoroughly first. .02
Old Apr 26, 2005 | 12:22 PM
Matt Gruber's Avatar
Matt Gruber
1. check fluid
2. check calipers/hoses for leaks.
3. check for sandals
Old Apr 26, 2005 | 12:25 PM
markdtn's Avatar
markdtn
Have you made any changes to the brakes recently or did this start suddenly?
Old Apr 26, 2005 | 06:26 PM
pdub's Avatar
pdub
4th Gear
my 77 did the same, get a master cylinder
Old Apr 27, 2005 | 06:05 PM
Chopper Larry's Avatar
Chopper Larry
I had a similar problem on my 80 and one of the front calipers was about to fall apart.
To Bottomless Brake Pedal
