Blinker wont cancel
Old Apr 28, 2005 | 10:11 AM
Garys 68's Avatar
Garys 68
Oh well, looks like I'l either try to find a "generic" replacement (from a 68 truck?) or try to fabricate something. If that doesn't work, I'll keep turning it off manually til I bite the bullet and spend the bucks.
Gary
Old Apr 28, 2005 | 10:21 AM
kens 80's Avatar
kens 80
If you go to motormite.com they show a replacement # 49300 or 49302. I dont know if its correct or not. they also show a picture of a 49301 that looks correct but says its for a Ford. I would go to either an Autozone, Advance or Pep boys and see if they have them. Cheap enough.
Old Apr 28, 2005 | 10:41 AM
BlueL36's Avatar
BlueL36
Cruise-In V Veteran
Cruise-In VI Veteran
sent you an IM on non-CF vendor source.
Old Apr 28, 2005 | 12:00 PM
Garys 68's Avatar
Garys 68
Got it, thanks. Almost afraid to call and get the price.
Gary
Old Apr 28, 2005 | 01:33 PM
ruby76's Avatar
ruby76
From: Fairview Heights Illinois, near Saint Louis MO, STL C3 Shark
Gary
Guess I better clarify, it was FOR my 68 truck. But my point was that local parts store had one. Some parts like that were "interchangeable" with other GM vehicles, so I suppose anything it possible. Then there is also salvage yards. Probably a part that would still survive a Vette that was "totaled" there is a Vette salvage yard in St Charles Missouri (just outside Saint Louis) with a website. they'd probably have one.
Old Apr 28, 2005 | 01:51 PM
Garys 68's Avatar
Garys 68
Yeah, I realize that regarding the truck. I think I'll take the old one with me to Autozone and see if I can find a similar one. I really dont care about numbers matching as long as it's drivable and reliable.
As for junk yards, I'm guessing I would have to buy the whole column. At least that's been my experience.
Gary
Old Apr 28, 2005 | 01:59 PM
Garys 68's Avatar
Garys 68
Who would have thought a part that should be $25 was going to be such a problem and could end up costing over $100 (if I could find it).
Oh well, just adding that to my 68 only parts. Ok it's on a 67, but that doesn't make it any easier to find.
Cats whiskers window seals
Windshield wiper mount assembly
Wiper door valve (none)
Can wiper door actuator and connector
Rear brake lines (top inlet on caliper)
Tach cable
Door latches and those trim rings
Seat latch location
Dash pad (ignition switch)
Gauge console
Vent *****
Fender louvers
Stingray badge (none)
Interior door panels
Left side exhaust manifold (alternator mount)
Reverse light switch
Backup light/rear valance
Wood steering wheel
Console belt pockets
Wheels
Side windows
Neutral lockout switch
Radiator/shroud, etc
Turn signal switch
Old Apr 28, 2005 | 02:15 PM
pef427's Avatar
pef427
Hey Gary, I checked the autozone and other major parts houses and all had part # 's for a 68' but none actually fit once they arrived. 69 and up! Everyone's literature and websites said they carry it but noone ever had it. When I tried converting to other switches they were all backwards when it came time to screw the blinker arm in or the hazard button...which didn't work anyway. I went with a tilt/tele from a later year.And I still love my 68'!
Old Apr 28, 2005 | 02:24 PM
Paul L's Avatar
Paul L
Believe me. You have to get the right part. Generics do not fit. Have you tried the fellow in Colorado?
Old Apr 28, 2005 | 02:28 PM
Garys 68's Avatar
Garys 68
Not yet, I was afraid to find out the price.
Gary
Old Apr 28, 2005 | 02:50 PM
Paul L's Avatar
Paul L
Probably about $150.00.
Old Apr 28, 2005 | 07:26 PM
Lorin D's Avatar
Lorin D
Default Blinker won't cancel
Have you tried a Chevy dealer ? That is where I ended up going when
I had problems and had to replace mine on my '71 . Juat a thought .
Old Apr 28, 2005 | 07:54 PM
  #33
Paul L's Avatar
Paul L
People do not seem to realize how difficult this part is to find. I wish to bump this up to the top until a source is located. I need a spare. IM if if you wish.
Old Apr 28, 2005 | 10:41 PM
  #34
kens 80's Avatar
kens 80
Hey Gary give this guy a call, I got the url from another thread: http://www.columnsgalore.com/
Old Apr 29, 2005 | 10:07 AM
  #35
Garys 68's Avatar
Garys 68
For $150, I could probably buy a used 69 tilt/tele column that uses the $29 switch.
For $300, I could even buy a new polished aluminum column from Summit!
Gary
