Originally Posted by DonBecker
Looks great Lars...
mind sharing the hours you have in it?
Every day after work and every weekend for the last several months. If I actually add it up I'll get all depressed and start drinking. Hey... that's not a bad idea! Think I'll have a beer.
Lars, absolutely awesome man. Very very impressive work. Its funny all along reading your descriptions I was thinking to myself how I was gonna say how the carb was too big. I guess that other post has taken on a life of its own huh. Well since you don't know anything about carbs anymore it seems as you have brushed up on your fabrication skills Totally cool car Lars and I gotta say you kept your cool in that other post more than I could have if I were you.
The drinking part I understand, but nothing to get depressed about, you do good work.
And I have to say, your articles are very well written.
Wow that is completely amazing ! I hope that one day I too can tackle such a cool project. Its obvious you have alot of work and time into this. Would love to see how you door line gaps turn(ed) out
Originally Posted by EDDIEJ82
I would tell you the carb was too big... if it had a carb on it!!! You must have taken the Dominator off while your waiting for the 650 to arrive.
Actually, the 1050 Dominator is loaned out to a guy who is running it on a small block Ford right now. He was running a 750, and the 1050 just dropped his ET and improved his mph. But I'm sure that's because the carb is too big. I should probably call the tech line at Barry Grant and get a qualified recommendation on carb sizing. Since the tech guys don't work on commission, that makes them very qualified to advise me... (what the heck did that have to do with anything..??) What a waste of time...
Originally Posted by lostpatrolman
Lars, did you guys custom makethe tube frame? If so, do you have any more detailed pics of the jig?
Yes, the entire cage/frame is custom made from scratch. We have a tube bender set up and bolted down to the patio outside the garage. The "jig" is nothing more than an I-Beam that we leveled very meticulously. All measurements and setups for the car were them taken off this "datum" to assure that we built everything square and level within .030". Initial portions of the car were actually welded to this beam with some standoffs. Once the cage & car could support itself, we cut it loose from the I-Beam and actually bolted it in place. We also built a couple of universal adjustable fixture stands that we used to position and clamp various members & sections "in space" until they could be welded into place on the cage. This allowed mocking up and visualizing various parts of the construction. For example, we clamped the front bumper to these adjustable supports and put the bumper where we wanted it to be. We then figured out what we needed to fabricate to attach the bumper to the cage. Cardboard and thin sheet metal was often used to create interfaces like this, and the actual brackets were then cut and welded in place while the bumper remained supported in space by the stands.
Exactly. Why do we have to keep hashing this out over and over. The guy said he had been on the forum for a long time, but lost his user name. He also said he reads most threads. I think he was just spoiling for this argument. I don't blame you at all for not responding.
The 355 we're using in the car came out of the previous Nova - it was rolled and wrecked last racing season. The old Nova had the full stock frame under it plus a cage - very heavy car. It ran low 12s, so this new car should run high 11s with no mods to the motor. But we're thinking about doing a few upgrades to get the car into the 10s - we'll see how far we get, since the priority is to just get the car on the track as quickly as possible.
The current engine is a stock-bottom 350, bored .030 (making it a 355) with flat-top pistons. We have Dart Iron Eagle heads running 12:1 compression and a big Comp solid flat tappet cam. Intake is a Victor Junior with a 1050 Dominator on it. This simple and basic combo ran low 12s in a full frame street legal car. Next step up is a full Jessel valvetrain and a cam upgrade...
Shouldn't somebody tell me the carb is too big and that I don't know what I'm doing...?
im sure its coming.....just hang in there fella..
awesome project.....please post finished pix, and a hole shot to boot!!
that's a pipe bender and it's junk, it applies all force to a small section and keeps pressure there, the tubing benders have a follower and an excentric ram, that means they actually move the section where the force is applied with the bend tangent creating a nice smooth bend, those things will dent the tubing if you make sharp bends, they are acceptable for slight bending but the other ones are mych better. Look into a greenlee type bender ($$$)
