Need help quick!! TH200R4
Old Apr 28, 2005 | 07:50 PM
GrandSportC3's Avatar
GrandSportC3
Cruise-In IV-V-VI-VII-VIII Veteran
St. Jude Donor '03, '06, '17
Default Need help quick!! TH200R4
Took the pan off and want to check out the governor. In this pic, what piece is the governor?
I assume that it's the piece on the bottom of the picture in the center but I just want to make sure!!
Old Apr 28, 2005 | 07:55 PM
jcswm's Avatar
jcswm
Why do you think Jeb Bush is in your Transmission????
Old Apr 28, 2005 | 07:56 PM
GrandSportC3
Old Apr 28, 2005 | 07:58 PM
EDDIEJ82's Avatar
EDDIEJ82
Oliver the governor isn't in the pan, It should be on the side of the trans under a round metal cap just above the pan. On a 700 it's in front of where the speed o cable goes in.
Old Apr 28, 2005 | 08:01 PM
GrandSportC3
A picture would be helpful..
Do I have to pull the filter??
Old Apr 28, 2005 | 08:02 PM
GrandSportC3
This is not a picture of the pan!! This is the bottom of my tranny...
Old Apr 28, 2005 | 08:03 PM
EDDIEJ82's Avatar
EDDIEJ82
I know what it is. Look on the side of the trans for a round metal cap. Hold on and I'll find you a pic
Old Apr 28, 2005 | 08:04 PM
GrandSportC3
What do I have to remove to get to it??
Old Apr 28, 2005 | 08:06 PM
EDDIEJ82's Avatar
EDDIEJ82
Here try this site. The link is for a pdf file. I don't know if it will link directly to it or not let me know
http://www.syty.huryde.com/html/tran...%20Rebuild.pdf
Old Apr 28, 2005 | 08:09 PM
EDDIEJ82's Avatar
EDDIEJ82
Round metal cap
Old Apr 28, 2005 | 08:11 PM
GrandSportC3
What page is the pic??
Old Apr 28, 2005 | 08:12 PM
GrandSportC3
Might be the thing on the right in the pic.. I looked at the entire bottom of the tranny and I don't see anything like that.. The speedo cable attaches just above the thing on the right side in the pic..
Old Apr 28, 2005 | 08:13 PM
GrandSportC3
It might be the thing on the right side that's held in place with the 4 bolts...
Old Apr 28, 2005 | 08:14 PM
EDDIEJ82's Avatar
EDDIEJ82
On my moniter it opens right to it.... but it is on the botton of page 4
Old Apr 28, 2005 | 08:17 PM
GrandSportC3
On the bottom of page 4 they show a pic of the outside of the tranny...
Old Apr 28, 2005 | 08:25 PM
EDDIEJ82's Avatar
EDDIEJ82
That's a 700. I was just looking at a 200 and they have a one peice case. Not exactly sure where it is on a 200 but I'll keep looking
Old Apr 28, 2005 | 08:29 PM
GrandSportC3
Found this site!!
http://www.gmhightechperformance.com...0407htp_trans/
To Need help quick!! TH200R4
Old Apr 28, 2005 | 08:30 PM
GrandSportC3
http://www.drwtransmission.com/thm_200-4r.htm
This one is interesting too..
but still no pic of the cap... I assume that it's the thing on the right...
Old Apr 28, 2005 | 08:31 PM
GrandSportC3
I'll just go ahead and remove the thing on the right... Worst case scenario, I'll have to put it back
Old Apr 28, 2005 | 08:44 PM
GrandSportC3
ok.. got the governor out and the spring did pop out indeed (like CPT suspected)
Now I wonder on which side the spring has to go?? It would fit in 2 ways...
