Stopping Headlight Vibration/Flicker
So, I developed a fix for this that takes just a few minutes to install.
Also, one of my headlight bearings is very bad, and this fix corrected that looseness too. Which was nice, since changing a headlight bearing is one of those Corvette jobs that you do not want to have to do if at all possible.
The fix:
1. Obtain (any hardware store) 4 toilet tank bolt seals and cut a 1/8 diameter notch in at as shown:
2. Raise headlights. Take the headlight bell housing off.
3. On each side of the headlight housing there is a pivot. You will see a collar with a set screw on each one too.
4. Loosen the collar enough to snap in the cut seal--it will snug into place. Now, while applying pressure to the collar, pressing it firmly against the seal, tighten the set screw.
5. Repeat on pivots--total of four. Replace bell housing.
You will now notice that your headlight housings are firm and solid--almost zero wiggle. This fix does not cause headlights to raise or lower any differently.
Like it’s said above this should be a temp fix until you have the time and money to do it right. I just can't bring myself to do stuff like that as a permanent fix. I have Bubba'ed some stuff on my car just so I can keep the system working but eventually I get the proper parts and fix it right. Sorry, no offense intended.
However, this does stop all vibration in the headlights--which you get some of even when the bearings are new.
Then have to listen to the person chuckle and say they only sell them in a kit with muffler bearings.
yeah that about the way it will go...if it ant broke....
