Vacuum connections
Old Apr 29, 2005 | 06:12 PM
Ak. Mal's Avatar
Ak. Mal
From: Kansas City, MO ...I'd like to go fishing and catch a fishstick. That'd be convenient. - Mitch Hedberg
Default Vacuum connections
Should there be a clamp on vacuum line connections or is the vacuum enough to seal the slip on connection? I've developed a vacuum leak and realized, that there are no connectors on any of the vacuum lines in the car. If the hose is new, but doesn't seal well causing a vacuum leak, what is the correct fix? Use a hose clamp or a smaller hose?
Old Apr 29, 2005 | 06:43 PM
griffths's Avatar
griffths
The only vacuum connection that uses a clamp is the power brake booster. All others are a friction fit. If you have a loose connection it is either due to incorrect sized or old vacuum hose (end is stretched out) or an incorrect sized fitting.
Where are you having the trouble?
Regards,
Jay
Old Apr 29, 2005 | 09:24 PM
Sharky Guam's Avatar
Sharky Guam
All the hoses are made a little longer than they need to be. So cut off the short portion of the hose that goes in to the fitting and push it back in. The hose portion around the fitting will expand with age. So unless the hose is brittle, just cutting that short portion off and reinserting should fix the problem.
Old Apr 29, 2005 | 10:06 PM
David427's Avatar
David427
what hoses are are leaking?
where didya get em?
Old Apr 29, 2005 | 10:55 PM
bobs77vet's Avatar
bobs77vet
From: Arlington Va Current ride 04 vert, previous vettes: 69 vert, 77 resto mod
Originally Posted by Ak. Mal
Should there be a clamp on vacuum line connections or is the vacuum enough to seal the slip on connection? ?
you would be amazed at what a difference 1/32 of an inch makes on the connection.....make sure your hoses are not bigger then the ports.
Old Apr 30, 2005 | 12:46 AM
Ak. Mal's Avatar
Ak. Mal
The large vacuum port on the rear that I am running to the power brake booster definatly did not fit tight enough. In fact, neither did the hose of the front running to the pcv valve. As a test, I used a small hose clamp on both hoses. The car idles so much smoother now.
Old Apr 30, 2005 | 04:02 AM
Aflac's Avatar
Aflac
Cruise-In 5, 6 & 10 Veteran
St. Jude Donor '09
I changed most of my hoses and i have no leaks... not a bad thing to do every now and then...
Old Apr 30, 2005 | 06:21 AM
carl a's Avatar
carl a
are your sure someone didnt put the wrong hose in?, i was sizing up some vaccume lines at the auto part store and noticed they had metric hoses,so that may be why its not a ''exact fit''
Old Apr 30, 2005 | 09:42 PM
Ak. Mal's Avatar
Ak. Mal
It's very possible.
Previous owner = idiot
To Vacuum connections
