Carburetor Power Piston Spring Selection
Old Apr 30, 2005 | 10:56 AM
joe73vette's Avatar
joe73vette
Default Carburetor Power Piston Spring Selection
I am going to experiment with the power piston spring in my Q-jet. I hooked up a vacuum gauge and drove around with my son taking readings. I have the Edelbrock spring kit that contains springs for 4", 5", 6" and 8" vacuum. I think I know what spring to select, but want some advice. I can always change it if it isn't working out.
Idle vacuum: 12-14" in drive, 16-17" in park
Cruise vacuum: 11-17"
Light acceleration vacuum: 8-9"
Medium acceleration vacuum: 6-6.5"
Heavy acceleration vacuum: 4-5"
Kickdown WOT acceleration vacuum: 0.5-1"
Thanks,
Joe
Old May 1, 2005 | 12:59 PM
joe73vette's Avatar
joe73vette
nobody brave enough to guess? LOL Joe
Old May 2, 2005 | 01:33 PM
lars's Avatar
lars
I'd go 6" to start.
Lars
Old May 2, 2005 | 01:56 PM
comp's Avatar
comp
Originally Posted by lars
I'd go 6" to start.
Lars
i'd follow him
Old May 2, 2005 | 04:52 PM
joe73vette's Avatar
joe73vette
Originally Posted by comp
i'd follow him
LOL safe bet. I was going to use the 6" spring, and if it seemed flat under medium acceleration go to 5". (or is it the other way around?) I'll defer to the expert on this one. Joe
Old May 2, 2005 | 04:56 PM
page62's Avatar
page62
I fiddled with these springs to cure a midrange "burble"...and ended up going in the wrong direction! The strongest spring did the trick for me. And I'd been thinking weaker springs would help. I was able to go back to the original spring when I did the head swap.
I think it's a pretty much a trial-and-error thing (except in Lars' case, due to his experience at this...)
Old May 2, 2005 | 08:01 PM
joe73vette's Avatar
joe73vette
AARRRGGGHHH! Why can't anything be simple? I was looking at the springs, the 6" spring is supposed to be black. But instead of Gold, Orange, Black and Yellow springs, I have Gold, Orange, Silver and (2) Yellow. I guess they forgot to paint the black one! The bag was still sealed, so I'll give it a shot. Joe
Old May 2, 2005 | 11:23 PM
comp's Avatar
comp
simple
Old May 3, 2005 | 02:41 PM
thevetterisbetter's Avatar
thevetterisbetter
I had to go with the 4" for my car. Otherwise the primaries leaked into the venturies at idle.
Old May 3, 2005 | 04:11 PM
comp's Avatar
comp
what was your idle vac.???? what cam you running ???
Old May 3, 2005 | 04:52 PM
joe73vette's Avatar
joe73vette
Just to let you know, the 6" spring smoothed out the low- to mid-throttle stumble real well. I still have a stumble when just opening the throttle after coasting with the throttle closed. I will re-set my idle mixture screws and also see if the primaries drip. My idle speed is a little high, 850 in park, but I don't think the throttle is open enough to engage the main circuit. Any other suggestions? Thanks, Joe
Old May 4, 2005 | 09:58 AM
thevetterisbetter
Idle vac was decent, around 12 I believe. I am running a CC 268 XE, with 1.6:1 roller rockers.
Old May 4, 2005 | 10:41 AM
comp's Avatar
comp
thanks
Old May 7, 2005 | 11:57 PM
cardo0's Avatar
cardo0
From: Las Vegas - Just stop perpetuating myths please.
Default Haven't measured my vacuum but i already know my car really sucks.
Thanks for sharing the test results Joe. Since our engine combo's are very similar (crane energizer 266, WP heads, Qjet) i'll know what to expect.
U think the carb pp needed a bigger spring from the cam change?
cardo0
Old May 8, 2005 | 09:26 PM
joe73vette's Avatar
joe73vette
I don't know, but I have to tell you the results were skewed. I found two good sized vacuum leaks yesterday, haven't started it since. I'll have to recheck my vacuum at various speeds. Joe
To Carburetor Power Piston Spring Selection
