Take the castle nuts off the two joints on the passanger side and pop them loose...probably need to hammer a pickle fork between there, but they'll eventually break free. Then you'll have all the clearance in the world to drop the pan. Hope you got a Fel Pro 1-piece gasket...makes life so much easier and better.
To remove the ps ram from the frame, are you talking about the 4 nuts holding the bracket? or pulling the ram out of the bracket? reason I ask is that I loosened the 4 bolts on the bracket and they are loose bolts, ie, dont appear welded to the inside of the frame...kinda concerns me...thanks.
The four nuts you loosened that retain the power steering ram bracket should be attached to bolts that are retained from the factory installation having two of the bolts attached to one bracket and the other two attached to a similiar bracket. This is why the bolts don't turn when you tighten the nuts. The bolt brackets should not fall in the frame just removing the bracket. However you could run some coat hanger wire around them to keep them from being bumped up into the frame.
