Leak down test
Old Apr 30, 2005 | 02:11 PM
Cali,68,L-79's Avatar
Cali,68,L-79
Default Leak down test
Well after reading http://forums.corvetteforum.com/show....php?t=1075452 I rechecked my readings I posted earlier with one big difference I thought "dynamic" compression meant with engine running, you know dynamic versus static OOOOPSSS. In the Navy we call that a "GCE" (great conceptual error) anyway with coil wire off I cranked it over 5 times each cylinder and heres what I got
DRY / WITH 2 PUMPS OF 80 WEIGHT
#1 155 160
#2 149 160
#3 150 157
#4 147 160
#5 150 162
#6 147 165
#7 155 160
#8 145 160
I'm happy!
Okay next step is going to Kragen Auto picking up the leak down tester and give that a try. I'm happy so far and maybe all I'm looking at is new valve seals versus a total rebuild.
Old Apr 30, 2005 | 03:08 PM
The Dude's Avatar
The Dude
Not bad looking numbers at all.
Old Apr 30, 2005 | 04:01 PM
norvalwilhelm's Avatar
norvalwilhelm
I thought that was a compression test. I thought with leak down you used shop air, put a set pressure in the cylinder and then measured how much was lost or leaked out giveing a leak down reading?
Old Apr 30, 2005 | 04:40 PM
stingry's Avatar
stingry
St. Jude Donor '05-'06
Dave,
Numbers look OK. Your wet numbers are close to mine dry but mine is a fresh rebuild. You do have higher compression though so I would figure a rebuild of your engine would yield 170-180PSI.
The 15PSI difference between dry/wet concerns me. I need an engine guru to jump in here. 15PSI sounds like enough pressure to push oil around to me hence it may well be blowpast the rings as suspected. Anyone have thoughts on this?
Cheers,
Pete
Old Apr 30, 2005 | 05:02 PM
Jughead's Avatar
Jughead
Senior Member since 1492
From: Just because I'm paranoid doesn't mean people aren't out to get me...
St. Jude Donor '09
Jughead's Avatar
Jughead
St. Jude Donor '09
Old Apr 30, 2005 | 08:58 PM
bobs77vet's Avatar
bobs77vet
From: Arlington Va Current ride 04 vert, previous vettes: 69 vert, 77 resto mod
Originally Posted by Cali,68,L-79
#1 155 160
#2 149 160
#3 150 157
#4 147 160
#5 150 162
#6 147 165
#7 155 160
#8 145 160
I'm happy!
so what that means to me is that you have some rings that are worn and valves are fine... is that what you are thinking?
Old Apr 30, 2005 | 11:22 PM
Cali,68,L-79
No I'm hoping it means the rings are fine. Well no one has a leak down tester available to rent out. Hopefully next week the 2 units are back to the store from whomever is borrowing them and I can do the leakdown test. that will be the true indication.
Old Apr 30, 2005 | 11:30 PM
Cali,68,L-79
Originally Posted by stingry
Dave,
Cheers,
Pete
Pete there are so many unknown variables involved such as are the heads stock, honestly I never checked, 64 or 72CC, how thick are the gaskets, has the heads been ported whatever. Given I don't know this till I rip the motor apart I can't be certain of the readings I should be seeing.
Old May 1, 2005 | 06:28 AM
stingry's Avatar
stingry
Cali,
With unknown enginen components its true the compression could be different. 160PSI is still healthy inmho.
My concern is that the difference between wet/dry is leaning towards your rings not sealing. I hope that your leakdown test proves otherwise.
Cheers,
Pete
Old May 1, 2005 | 07:43 AM
Matt Gruber's Avatar
Matt Gruber
with 145 there is plenty of room for improvement
Old May 1, 2005 | 09:05 AM
bobs77vet's Avatar
bobs77vet
i thought the theory went that if the oil increases compression it is because it creates a small film on the cylinder walls indicating that the rings were not as tight or sealing as well as before....if the oil does nothing to incease compression then the problem is the valves
Old May 1, 2005 | 11:29 AM
Cali,68,L-79
Well my theory, and it's just a theory, when you crank over the engine five times the oil pump will splash up to the botttom of the rings and it will drip down. Succeding turning over of the engine for the rest of the cylinders will continue to load the block with oil from the pan so there still should be some oil at the rings making any increase in oil say the 80 weight I shot in the spark plug hole insignificant. Maybe I'm just hopeful. Who knows.
Old May 1, 2005 | 11:53 AM
LiveandLetDrive's Avatar
LiveandLetDrive
But it did make a difference?
Old May 1, 2005 | 11:59 AM
Cali,68,L-79
10psi. I'm assuming that's a good thing. If the rings were bad than I should have seen a significant spike in PSI and I did not. Again the true test will be the leak down test. I wish someone locally had a leak down guage to borrow. I'm not paying $115 for something I use once.
Old May 1, 2005 | 12:05 PM
bobs77vet's Avatar
bobs77vet
i don't think so, but i hope i'm wrong for your sake...the bottom ring is and oil scaper ring its mission is to stop the oil from getting by it....the top rings are the compression rings thats why the oil you shot in there made a difference.
To Leak down test
