350 HO crate
Old Apr 30, 2005 | 06:24 PM
Roadster71's Avatar
Roadster71
Default 350 HO crate
I'm still procrastinating about what to do about a engine for my 71. So, I have another question. What intake manifolds are available that will allow proper clearance with a stock smallblock hood with the 350 HO engine. All the Eldenbrock vortec manifolds say they will not fit under a corvette hood.
Old Apr 30, 2005 | 06:39 PM
jcswm's Avatar
jcswm
GM Performance has 2 intakes for the Vortec engine, made to fit under a Corvette hood.
Old Apr 30, 2005 | 06:41 PM
jdmick's Avatar
jdmick
Before I put in my 350 HO I had the stock engine with an old Torker intake which is probably a little taller than an Edelbrock Vortec intake. I needed a different air cleaner to clear the electric choke on a 1406 carb I put on before the engine swap. I finally found a setup that would work. I bought an offset base air cleaner from Jegs with a 2" tall filter. Then I had to cut about a half inch off the base by using a Dremel tool with a bolt clamped on to get a nice even cut around it. If someone makes an offset drop base air cleaner that works with a 1406 I wasn't able to find it. I haven't checked my hood clearance with the new Vortec setup but I doubt you would have to cut the base for the 350 HO with a regular Edelbrock Vortec intake.
http://www.jegs.com/cgi-bin/ncommerc...84&prmenbr=361
Old Apr 30, 2005 | 06:52 PM
Roadster71's Avatar
Roadster71
The 68 thru 72 hoods have a little less room than 73 and on. What p/n for the GM performance products manifolds?
Also, how do you folks like the 350 HO crates?
Old Apr 30, 2005 | 07:07 PM
jdmick's Avatar
jdmick
So far I've only got about 10 miles on mine (from my garage to the body shop on salty roads) but I can say it is a mighty improvement over my wore out L48.
Old Apr 30, 2005 | 07:28 PM
Sarge81's Avatar
Sarge81
I have the 350 H.O. engine in my '81. The intake manifold is the Edelbrock Vortec Performer, With a Edelbrock 1904 Q-jet carb. I've had it in the car for over 4 yrs. now. No problems with it. I upgraded the valve springs and install a LT4 Hotcam last year. That really woke it up a little. I had to do like "jdmick" did to his drop base air cleaner.
Hopefully next year if I finish getting the rest of my parts for the Tuned Port Injection system, I will get that installed. And I have the Nitrous system for the TPI also. So we'll see how really strong this engine is.
Darryl
Old Apr 30, 2005 | 07:40 PM
jcswm's Avatar
jcswm
GMpartsdirect.com
I've got Manifold part #12496820 and a Hotcam
just knowing my #'s matching l-82 is safe on a engine stand makes my car ALOT more fun to drive
Old Apr 30, 2005 | 08:12 PM
LFZ's Avatar
LFZ
I just helped my neighbor install this engine in his car...it runs great, sounds nice on flowmaster 40s. You can fit an Edelbrock Performer for Vortec heads under a stock small block hood.
Old May 1, 2005 | 11:17 AM
DRKCYDE's Avatar
DRKCYDE
Cruise-In VII & IX Veteran
I have the 330hp 350 H.O. deluxe, and love it.
Old May 1, 2005 | 12:32 PM
Roadster71's Avatar
Roadster71
Thanks for all the responses. Does anybody have this engine in a 68 thru 72?
To 350 HO crate
