Header studs again..need suggestions
Old May 3, 2005 | 06:02 PM
LFZ's Avatar
LFZ
Default Header studs again..need suggestions
Well i'm back at it again with another header leak! I finally got my ARP header studs to work...question, do you guys use locktite? anti-seize? or Copper RTV when screwing the studs into the heads? whats the best way to seal them?? I remember Gkull mentioning something he did and never had to re-tighten them? thanks.
Old May 3, 2005 | 07:12 PM
Red 69's Avatar
Red 69
Stage 8 bolts, install them right and they stay tight.
Old May 3, 2005 | 08:36 PM
MotorHead's Avatar
MotorHead
From: Who says "Nothing is impossible" ? I've been doing nothing for years.
I would use antisieze on aluminum heads. I have a question for you, are these the ARP studs part#100-1412 ? I bought a set and without taking them out of the package I could see the nuts were going to be too big to clear the headers, did you get smaller nuts or somethng or did the nuts that came with the package work with your headers ?
Old May 4, 2005 | 12:39 AM
LFZ's Avatar
LFZ
Motorhead, those are the same studs I bought. Yes they are indeed way too big to just go on with no problems. I had to ding alittle around my primaries to get them to go ..but I have 1 5/8" primaries. Aren't you running Hookers? or 1 7/8" primaries?? if so, they'll never work..theres a different pn# for the studs that clear for the bigger primaries.
Old May 4, 2005 | 02:31 AM
gkull's Avatar
gkull
You have to get the universal small nut fine thread. I didn't intend to take them out so I locktighted them in. Then I put a dab of Permatex red high temp on the nut to the header flange and they never come off.
Stage 8 don't work unless you have small headers Also they are junk because they have such short bolts. Very few threads for thick flange headers They should not be used with aluminum heads!
lock tight is the red running down - just spray with carb cleaner and wipe off before it dries
Old May 4, 2005 | 08:30 AM
MotorHead's Avatar
MotorHead
I have 1 3/4 in. primaries on the Hookers, I am going to try and find an nut that is smaller and doesn't have the washer built in like the ARP nuts. I want to use the studs because my headers are on and off all the time and I don't like screwinig bolts into aluminum over and over. Now if I could just find a way to do the same thing with my fabricated valve covers...
Old May 4, 2005 | 09:27 AM
BSeery's Avatar
BSeery
From: Exiled to Richmond, VA - Finally sold my house in Murfreesboro, TN ?? Corner of "Bumf*&k and 'You've got a purdy mouth'."
CI 6-7-8 Veteran
CI-VIII Burnout Champ
St. Jude Donor '06-'10, '13
You can get Stage 8 locks and bolts in 1" length. Another idea is the new Breslin Split Lock bolts. I want to know if anyone has used them yet.
http://store.summitracing.com/defaul...h.asp&N=400431
Old May 4, 2005 | 09:41 AM
jdmick's Avatar
jdmick
I've got the Stage 8s but those Breslins look a whole lot simpler to put in. No grinding parts to fit, no clips, and more room. I think the only questions are whether the inner screw would work loose and what would they be like to get out once any corrosion sets in with the cuts in the bolt.
Old May 4, 2005 | 10:02 PM
BSeery's Avatar
BSeery
CI 6-7-8 Veteran
My concern with the Breslin locks is getting the allen wrench in to turn the inner bolt with the header tubes in the way. My front and rear header tubes bend in a way that you can not get straight in access to the bolts on the inside of those tubes.
Old May 5, 2005 | 08:26 PM
C3 Stroker's Avatar
C3 Stroker
I prefer to use bolts to attach headers, but if you prefer studs & you want them to stay, always use Loctite & NEVER use anti-seize. (Even with aluminum heads....studs are not something you want to come aloose easily).
To Header studs again..need suggestions
