BB intake options
Old May 3, 2005 | 09:59 PM
guvnerwl's Avatar
guvnerwl
St. Jude Contributor
Default BB intake options
Greetings! I've got a Jeb built 496 in a '70 with a Turbo hood with an Edelbrock Victor intake. I need to go to a Victor Jr. or an AirGap due to interference with the hood. Anybody out there got any experience with such a change? The hp rolls over at about 6600 rpm (526 rwhp). My gut says los up top won't be that severe, but that's an unintelligent guess. I don't really want the lower/midrange torque an AirGap would bring - can't handle what I've got now.
Here's a pic http://forums.corvetteforum.com/phot...cat/500/page/1
Any thoughts appreciated
Carl
Old May 3, 2005 | 10:21 PM
69 N.O.X. RATT's Avatar
69 N.O.X. RATT
From: Pettis Performance 565 with two stages of Nitrous Supply nitrous 1.082, 4.61 at 155, 7.17 at 192
The Victor Jr. won't fit either. The Air Gap might, but will choke the motor if you run an air cleaner; been there done that.
526 rwhp is stout, what is the engine build?
Old May 3, 2005 | 10:40 PM
Jughead's Avatar
Jughead
Senior Member since 1492
From: Just because I'm paranoid doesn't mean people aren't out to get me...
St. Jude Donor '09
Good numbers thru factory side exhaust.
Old May 3, 2005 | 10:47 PM
guvnerwl's Avatar
guvnerwl
The air cleaner just touches the hood with the Victor - the Victor Jr. should be about 1/4 inch shorter. I had an AirGap on the previous BB - it fit easily - this is a tall hood.
That pic is a little dated. The current exhaust is not close to factory - but still side - The side pipes are actually 2 - 4 inch DynoMax mufflers cut and welded together - full headers with 3 inch mandrel bends to the side - I figure the exhaust is costing about 60-75 hp - I just like sidepipes!
Carl
Old May 3, 2005 | 11:57 PM
69 N.O.X. RATT
Did you chassis dyno the motor with and without an air cleaner with the Air Gap? if not, you may be surprised. Unless the previous motor was very mild. With the current 500+ rwhp the hood (with air cleaner) will cause a restriction.
I have a 69 and tried everything with my 454, L-88 hood and an Air Gap. After cutting and fitting, etc, etc. The best I could do is -35 rwhp with the air cleaner on.
Old May 4, 2005 | 12:02 AM
427Hotrod's Avatar
427Hotrod
2020 C2 of the Year - Modified Winner
2020 Corvette of the Year (performance mods)
C2 of Year Winner (performance mods) 2019
2017 C2 of Year Finalist
You can mill the intake carb pad to match the angle of Holley Strip Dominator. There are a couple of guys here with 540's that have done that and it seems to work fine. This lowers the front of carb similar to a stock intakes' angle.
JIM
Old May 4, 2005 | 01:50 PM
guvnerwl's Avatar
guvnerwl
RATT, I had a similar experience on the previous motor. It was more of a choke horn problem. I took the choke horn off and got most of the difference back. This engine has a Holley HP 950 - no choke horn - but, I've not tried with/without yet.
Old May 4, 2005 | 04:59 PM
69 N.O.X. RATT
JIM
Yep as usual, great idea Jim. I knew that too. I wish I would have said it first
To BB intake options
