Reverse Lights....
Old May 4, 2005 | 02:17 PM
Rip76's Avatar
Rip76
2nd Gear
Default Reverse Lights....
Hi, I'm new to the forum.
I just purchased this '72
http://i3.photobucket.com/albums/y62/Rip76/000_0076.jpg
The reverse lights are not working, and I'm suspecting something in the shifter or transmission?
Thanks in advance.
Rip76
Old May 4, 2005 | 04:27 PM
Gordonm's Avatar
Gordonm
There is a switch on the transmission that controls the back up lights. First see if it is there. A lot have been taken off. Check to see if the linkage is attached to the reverse arm. I am assuming it is a 4 speed. If it is there look to see if the wiring is there. Two wires a green and pink one should go up into a connecter on the firewall. This then goes inside the cabin. Obviuosly check the bulbs and the sockets. The sockets will sometimes get some rust in them. Also check for good ground wires.
If it is an auto the switch is on the shifter handle. The wire colors are the same pink and green. Check to see if it is there and hooked up.
Old May 4, 2005 | 04:45 PM
Rip76's Avatar
Rip76
2nd Gear
Thanks Gordon.
It is an automatic. So basically I just take off the console surrounding the shifter and see if they are hooked up.
Old May 4, 2005 | 05:06 PM
Gordonm's Avatar
Gordonm
Yes. The switch will be attached to the shifter. If you connect the pink and green wires the reverse lights should go on. If they do it is in the switch, either bad or needs adjusting. It is on a sliding bracket if I remember correctly.
To Reverse Lights....
