slow power window
Old May 4, 2005 | 11:12 AM
tigers123's Avatar
tigers123
Default slow power window
My driver side power window is extremely slow. You have to assist it with your hand to pull it up. What should I look foir when repairing? Bad motor, wiring connections, or tracks?
Old May 4, 2005 | 11:22 AM
fast idle's Avatar
fast idle
if it still operational just slow, a good cleaning and oiling of the tracks and mechanisms should fix it . worked on mine
Old May 4, 2005 | 01:21 PM
Biker's Avatar
Biker
In addition to cleaning/oiling the tracks and lift mechanism, also check the integrity of the wiring. Make sure there are no shorts or bad insulation, and ensure the connections are clean and tight.
Old May 4, 2005 | 07:14 PM
BKbroiler's Avatar
BKbroiler
If it goes down quicker than normal and up slower than normal, the spring in the window regulator is broken. It happened to me.
To slow power window
