While I have the core support and radiator out to have the frame fixed, I figured I would fix the core support. Well, the rot was worse than I suspected.
I am debating whether to try and fix all the rot using patches, or simply make a new core support. I am going to be mounting some electric fans, so I am going to be making some brackets anyway. I was thinking about making the support out of 2x2 square tubing. Any thoughts or opinions on which way to go?
I think I am going to start patching it, and if that doesn't go as well as I hope, then I will look at making one. The biggest problem I see with making one out of tubing, is that it appears the vertical pieces actually bend in a little where the support bolts to the body.
From: Arlington Va Current ride 04 vert, previous vettes: 69 vert, 77 resto mod
this is what i did, these are the tack welds before i finished welding
Ken, That doesn't look so bad. For a '68 support that I re-did, I had a local sheetmetal shop bend up some new lower section pieces and then plug welded the parts together to make a new lower section that looked exactly like the original, then I MIG welded the new section in place, ground the weld bead flush, and the support looked like new after. I've got a spot welder now so I don't even need to plug weld. If you want, bring the support by later this week and maybe I can help. It's the least I can do for "wheel rental".
The sheet metal shop fabbed the pieces for me for the cost of lunch for the guys working there. Pizza for all!!!
Bobs77: Nice work!
Around '97-98 or so at the last Cypress show, I bought a replacement support, 225 bux or so....it was thinner metal and lighter than even the old holy POS in there....I drilled holes in the lower back section to let water drain out, and plugged all top holes with my favorite black RTV...should last long as I do....
otherwise, maybe I can get the guy who tigged up my grill to tig up something super lightweight....
I have access to a sheet metal shop and welding equipment so I fabricated the bottom 6" of my support from 16 gauge black iron. Made it exactly like the original, it's really hard to tell it's been replaced. Looking back at all the hours I had wrapped up in the project I figured I will never do that again as long as I live.
I took my support out last week to have the radiator boiled out and found what you all did. Mine isn't too bad. Mostly small pin holes along the bottom channel. I was going to por-15 it and hope for the best. It seems pretty solid along most other lines. What are you guys going to do for the seals (sponge rubber)? Mine are pretty stiff and I would like to replace them. What did you use to replace them?
Thanks for the pictures you included. I have got to get a digital...
one more thing. On the support, the lower radiator support brackets have a bolt on each side that appears to be welded on to the support. The bolts are the ones that the bottom of the shroud attaches to. When i removed mine they both snapped off. I don't have a welder, I was thinking of grinding the broken ones off and putting in some type of lag bolt. Any of you have that problem or have a fix you used?
I got two sections repaired last night. There is a lot of grinding to make it look good, but the sections came out well. The biggest challenge now is fixing the section on the bottom that runs the width of the support. The whole thing is rotted. The area I am talking about is in this pic, right beneath the flange. I cut the flange off, and there was nothing left under it.
