Overheating
Old May 6, 2005 | 08:50 PM
69'Silver's Avatar
69'Silver
Default Overheating
I just got the car running tonight and was trying to set the timing and it is now heating up to 250 deg in a big hurry. This car ran at about 180 deg. before this. The side pipes even started smoking. Here is what has been done.
1) New water pump belt...original seemed to long and had a lot of play
2) New ignition components... Cap, Rotor, Ignitor 2 flame thrower 2,
Usually when a water pump goes they start leaking right, or will the impellers ever fail?
Old May 6, 2005 | 08:54 PM
gearheaddroppings's Avatar
gearheaddroppings
St. Jude Donor '05-'06-'07-'08-'09-'10
Check the obvious. If it got there in a real hurry, you have something blocking the flow. Assuming that the cooling system is filled all of the way, I would check the thermostat right away.
If it looks good, make sure you have water flowing through both hoses.
62fuelie's Avatar
62fuelie
You were trying to set the timing..... Timing is very important to proper operating temp. Suggest you revisit the timing.
Old May 6, 2005 | 10:24 PM
rihwoods's Avatar
rihwoods
Some of the time,rapid temperature rise means the thermostat is stuck.Just change it to be sure.They are cheap.Assuming of course,you have already checked for leaks,and you can see coolant in the filler neck of your radiator when it is cold.
Old May 7, 2005 | 01:56 AM
Empatho's Avatar
Empatho
timing cause an engine to over heat
Old May 7, 2005 | 11:27 AM
isosceles's Avatar
isosceles
did you plug the vacuum line that was attached to the vac advance?A large vacuum leak can cause that as well. Also, make sure the timing has enough advance.
To Overheating
