Timing question
Old May 7, 2005 | 09:23 PM
kodaclr's Avatar
kodaclr
Default Timing question
What is the timing for a 1969 350, 300hp automatic.
I thought it was 8 degs, but I found the original owners manual and it say 4 degs.
Old May 7, 2005 | 10:36 PM
BigBlockk's Avatar
BigBlockk
You should try to get the initial advance up to 12 to 18 degrees. This adds a lot response to the throttle.
BigBlockk
Later.....
Old May 7, 2005 | 11:01 PM
kodaclr's Avatar
kodaclr
Thank You
Old May 8, 2005 | 07:08 AM
62fuelie's Avatar
62fuelie
If you will check the archives, you will find tons of info on timing. You need to check the total of initial and mechanical advance with the vacuum disconnected and pluged. With all the mechanical in, you should be at around 36*. You need a dial-back timing light or a timing tape to do this with. The vacuum advance will typically add another 14-16* at steady throttle settings.
If you just arbitrarily set the initial advance to some greater number, you have no idea what the total advance is, and could run into detonation problems if you are exceeding 36-38*.
Old May 8, 2005 | 08:10 AM
Gordonm's Avatar
Gordonm
Looking at the specs for the 69 300 hp motor the dist will give you 30 degrees centrifucal advance. If you set it at 4 degrees (what the specs call for) you will have a total of 34 degrees. If you set it at 18 initial you will have 48 total (way to much) The advance curve is horrible for this dist. It is all in at 5100 rpm. You should have it all in at 2500 to 3000 rpm. Most stock dist. are setup very poorly from the factory. My advice is find someone with an old dist. machine and have it setup correctly. Chances are it is need of a rebuild and recurve anyway. This being setup properly will make the car much more responsive and more power through the rpm range.
Old May 8, 2005 | 09:38 AM
page62's Avatar
page62
Download a copy of Lars timing paper at www.corvettefaq.com
It explains the process and the reasons "why"
Old May 8, 2005 | 09:41 AM
kodaclr's Avatar
kodaclr
Thanks for all the advice, I did get Lars paper.
Boy even checking and setting the timing is not easy.
I do have a adjustable timing light,
Old May 8, 2005 | 10:28 AM
greyghost79's Avatar
greyghost79
BigBlockk
Later.....
Old May 8, 2005 | 10:29 AM
page62's Avatar
page62
Actually, once you get the hang of it....it's easy. I can do it in about 30 seconds. (Okay, maybe 2 minutes)
1. Hook up the light.
2. Loosen distributor (not too much) and disconnect vac advance
3. Rev engine until timing mark stops advancing and check timing for 36-38°
4. Adjust and tighten distributor
5. Recheck and test drive
6. Open and drink
Old May 8, 2005 | 10:36 AM
kodaclr's Avatar
kodaclr
Thanks, I'm on my way out there now to do it
Old May 8, 2005 | 10:37 AM
page62's Avatar
page62
Oh...and do it with the engine warmed up!
To Timing question
