intake height
Old May 9, 2005 | 07:04 AM
gator79's Avatar
gator79
Default intake height
what intake and carb setups will fit under the stock hood on my 81? I was thinking of an Edelbrock performer with a holley dual feed 650. the car does have a nitrous setup so there is a 1/2 inch spacer under the carb for the nitrous. all emission controls will be removed. thanks
Old May 16, 2005 | 06:50 PM
lebvette's Avatar
lebvette
St. Jude Donor '08-'09-'10-'11-'12-'13-'14-'15-'16-'17-'18-‘19-'20-'21
Default intake and carb
I have a rpm air gap with a holley street advenger on a 82. It fit under the hood with a low profile air cleaner. I used one of the new air cleaners with the filtered top. A 82 hood is a little different from yours. It has some meat inside to fit around the air cleaner. I had to trim some of that off to make it work.
Old May 16, 2005 | 06:55 PM
bobs77vet's Avatar
bobs77vet
From: Arlington Va Current ride 04 vert, previous vettes: 69 vert, 77 resto mod
sounds similar to my 77 performer,1/2" spacer and speed demon with a drop base air filter
Old May 16, 2005 | 08:18 PM
73jst4fun's Avatar
73jst4fun
Got any pics of your air gap and carb on the engine, I'm thinking of installing an air gap manifold with my speed demon with a low profile air cleaner, I'm pretty sure it will fit under a stock 73 hood.....
Old May 16, 2005 | 08:53 PM
AGVI's Avatar
AGVI
Canadian Events Coordinator
performer with a holley dual feed 650 will work, so will the RPM with a drop base air cleaner.
I'm going for the RPM air gap with my 650 Speed Demon. It's the same height as my current manifold - performer RPM
Les
Old May 17, 2005 | 07:12 AM
vetteonr's Avatar
vetteonr
I just installed this rpm manifold with a Edelbrock carb on my '80 and it fits fine........
Old May 17, 2005 | 07:43 AM
Pauld's Avatar
Pauld
Looks a nice install. I always worry about that type of air cleaner, I heard that they can be a fire hazard.
Old May 17, 2005 | 12:32 PM
Entropy's Avatar
Entropy
Ditto on the fire hazard, also can be a carb hazard...buddy of mine installed one, installed the dist. backwards (180 degrees off) backfired through the carb, and then he spent the next 2 months with an ice pick removing all the nice melted foam...moral of the story, talk to lars before installing a dist.
Old May 17, 2005 | 12:43 PM
djgrelli's Avatar
djgrelli
You're quite right on that air cleaner. That foam catches on fire very easily. Threw mine right in the garbage.
Old May 20, 2005 | 12:54 AM
hoosiervette's Avatar
hoosiervette
St. Jude Donor '14-'15-'16
I'm putting a new engine in my 74. I put vortec heads on it. I called Edlebrock to see what intake to use. They told me that they couldn't guarantee that any of their intakes would clear my stock hood. Anyone else tried it on a 74? How much difference is there in hood designs?
Old May 20, 2005 | 07:25 AM
vetteonr's Avatar
vetteonr
I've never heard that about the foam air cleaner being a fire hazard. I've had this one for about 4 years now without a problem. Maybe I'll have to re-think my set up.
Old May 20, 2005 | 07:48 AM
captainmorgan's Avatar
captainmorgan
I just put on a Edelbrock Performer RPM and a 575 Speed Demon with a drop base air cleaner on my '77. Seems to fit fine.
Old May 20, 2005 | 07:56 AM
Ganey's Avatar
Ganey
Originally Posted by hoosiervette
... I put vortec heads on it. I called Edlebrock to see what intake to use. They told me that they couldn't guarantee that any of their intakes would clear my stock hood. Anyone else tried it on a 74?
Victor Jr., RPMs (incl. Vortec) & others will work fine w/ the 73-79 med. rise hood & aftermarket drop base air filter.
Old May 23, 2005 | 10:07 AM
hoosiervette
Thanks for the info. I'll give it a try.
Old May 23, 2005 | 10:46 AM
The Money Pit's Avatar
The Money Pit
I've run the Performer intake with a drop base air filter and a 4" element with minor rubbing as a test.Ended up going with a 3" element. I used the same 3" element with an RPM intake with no clearance issues,and now run with a Vic. Jr.,all under the stock 80 hood.
To intake height
