Old May 14, 2005 | 09:18 AM
Dalannex's Avatar
Dalannex
Anybody know what the stock cylinder head chamber and runner sizes are on the 1981 350?
-Justin
Old May 14, 2005 | 01:53 PM
MEGALADON's Avatar
MEGALADON
From: WAY DEEP INSIDE AMERICO,YES YOU LIVE HERE TO!! TX
-Justin
Good question lets here it for the 82 heads also
Old May 14, 2005 | 02:32 PM
1BAD80's Avatar
1BAD80
They are 76cc's.
Here are 2 sites with the flow & valve size.
http://users.erols.com/srweiss/tablehdc.htm#tabtop
http://www.mortec.com/castnum.htm
Yes the port matching is worth the little work.
Old May 15, 2005 | 10:14 AM
Dalannex's Avatar
Dalannex
My sportsman II's are 72 cc. So, if I would put the stock heads off of my 81' motor on my current motor (10.25:1 CR) and my sportsman II's on my stock 81' 350 I would end up with higher compression on the stock 81' motor and lower compression on my current motor, correct? And, from looking at the links above it appears as though the Sportman II's don't flow much better than the stock heads. Is this correct?
-Justin
Old May 15, 2005 | 06:58 PM
MEGALADON's Avatar
MEGALADON
-Justin
Yes you arte correct
Old May 15, 2005 | 07:00 PM
MEGALADON's Avatar
MEGALADON
-Justin
Not sure on that . I am going to port match the stealth manifold
and the stock heads and see If there is a difference
