Techniques for Sanding a Corvette
I'm ready to start sanding my 1980 Corvette to prep for paint. Do any of you have a guide you've written up for the novice?
What grit sandpaper to start with?
What grit sandpaper to finish with?
Should I go down to the gel coat?
Can I use an electric palm sander?
Tricks, tips & do's and dont's.......
Thanks in advance for you help!
never use an electric palm sander,do get yourself a good quality hard sanding block(not a sponge)
i block sanded the car with 280 grit,then 320,then reblock with 400. prime then scuff with 400 paper again.
research a bit on how to block sand properly and the body will be straighter than factory.
never hand sand anything....ever.... you will regret it.
TJ
If you are stripping the paint, and don't want to use stripper or razor blade, then 80 will take the paint off quick. Prime with catalyst primer, block sand wet with 400.
BTW....you can use an air powered or electric hand sander with the 80 grid, but be careful not to go past the factory primer. There is no need to strip the factory primer unless you are doing panel repair.
