What causes crankcase pressure?
Old May 9, 2005 | 07:40 PM
jerryjfunk's Avatar
jerryjfunk
Default What causes crankcase pressure?
My PCV valve keeps popping out of the valve cover, spraying my engine bay with oil. The valve is tight and shouldn't be coming out. Does anyone know what causes this or how it can be solved?
Thanks!
Old May 9, 2005 | 07:50 PM
Z-man's Avatar
Z-man
Crankcase pressure comes from the explosions above the pistons. A little bit sneaks by each power stroke (blowby). This gas ends up in the crankcase and if it has no where else to go, it builds up pressure.
Is your PCV valve inserted in the right direction? It's kind of a one-way valve. I'd also check to make sure it isn't plugged.
Old May 9, 2005 | 07:56 PM
jerryjfunk's Avatar
jerryjfunk
I replaced it just today and it's definitely in the right way... is it possible that I'm getting excessive blow-by? This worries me...
Old May 9, 2005 | 08:14 PM
page62's Avatar
page62
How is the breather hole on your other valve cover configured?
Old May 9, 2005 | 08:52 PM
rponfick's Avatar
rponfick
If the pressure build up in the crankcase is more than the PCV can suck out, you have a problem. A leak-down test will help isolate the problem. It is similar to a compression test but more diagonistic. Usually excessive blowby the piston rings will pressurize to crankcase above normal levels.
To What causes crankcase pressure?
