fuel guage stuck
Old May 10, 2005 | 03:09 PM
stroked75's Avatar
stroked75
Cruising
Default fuel guage stuck
Saturday I pulled my vette up on ramps to change the oil. When I backed off of them the fuel guage was stuck in the 3 o-clock position.Can anyone tell me what might be wrong and/or how to fix it. Thanks
Old May 10, 2005 | 04:11 PM
johnt365's Avatar
johnt365
could it be possible that the float part of the sending unit in the tank got stuck from being on an incline?
i would open the gas tank and look to see if i could see the float and make sure it moved. maybe get coat hanger and free it up when its almost out of gas...
Old May 10, 2005 | 04:24 PM
Chopper Larry's Avatar
Chopper Larry
My 80 just did the same thing after filling up....I will never try to "top it off" again if the coat hanger thing works.
Old May 10, 2005 | 09:11 PM
stroked75's Avatar
stroked75
Cruising
I tried the hanger and was able to move the float up and down, but still no change. The guage is still stuck or just won't move. What else can I try?
Old May 10, 2005 | 10:44 PM
SteveG75's Avatar
SteveG75
I had the same problem once. You have loose connection in the fuel level wiring.
There is a two wire harness on the driver's side of the tank, check the connection there. The sender connections are on top of the tank. There is a sender and a ground. To get access, remove the lid (four screws around the edge) and then pull up on the rubber surrounding the filler neck.
I had a loose ground wire and it caused the same problem.
Good luck.
Old May 10, 2005 | 11:22 PM
stroked75's Avatar
stroked75
Cruising
I checked the ground and it was good also grounded out the pos. wire and the guage went up to half tank, then removed the grounding wire and back to 3 O-clock it went.What else do you think it could be? Thanks
Old May 13, 2005 | 10:58 PM
stroked75's Avatar
stroked75
Cruising
Got it fixed!!!!! tank sending unit gone bad, not bad for going up and down for thirty years. Thanks for the help.
To fuel guage stuck
