Engine Question
Old May 11, 2005 | 08:48 AM
Dale73's Avatar
Dale73
Cruising
Default Engine Question
I was wondering if anyone else has ever had this problem My 1973 Vette w/L82 runs smooth, idles smooth but at all speeds you can feel it lunging. It feels like you are pressing the gas on and off....kind of like varing the speed up and down up and down. You cant see anything on the speedometer (I mean its not losing speed). It is just driving me CRAZY. If anyone has heard of this please let me know what could be causing this.
Old May 11, 2005 | 08:57 AM
page62's Avatar
page62
Kinda like surging? Have you checked the timing and the vacuum advance function?
Old May 11, 2005 | 08:58 AM
Steve's74's Avatar
Steve's74
This can be casued by several things. Overadvanced ignition timing, lean fuel mixture, or an overactive (weak diaphragm spring) EGR valve can cause this. For a quick check on the EGR, simply remove and plug the vacuum hose temporarily and take it for a drive. I wouldn't suggest leaving it disconnected permanently though.
Steve
Old May 11, 2005 | 10:48 AM
Dale73's Avatar
Dale73
Cruising
Yes, it's a surge that happens all all speeds. You do not feel it on acceleration. But it is felt say if you try to hold it at 55. The surge is very suddle feeling. Not bucking.
Old May 11, 2005 | 11:14 AM
Boofers's Avatar
Boofers
Have you done anything to your engine recently, how did this start happenning?
What is the difference with an engine accelerating and cruising - vacuum level... Accelerating (load) = low vacuum and cruise you have lots of vacuum. First check your vacuum advance & timing, vacuum leaks or EGR like has been mentioned.
how to set your timing for peak peformance by Lars
If you rule out all your timing & vacuum leaks then the carb is next. What carb do you have? Here are some carb links you may find usefull...
corvettefaq.com carb tuning links
Old May 11, 2005 | 11:15 AM
page62's Avatar
page62
I'm gonna quote Lars here: "...the car will chug and jerk at cruise from (an) over-advanced condition."
If that sounds, correct, check your timing (it can't hurt). And while you're in there, check your mechanical and vacuum advance systems for proper functioning. Download a copy of Lars timing paper from www.corvettefaq.com if you're not familiar with the technique we commonly use around here.
Old May 11, 2005 | 11:43 AM
Dale73's Avatar
Dale73
Cruising
Thanks, I will check the vacuum advance & timing, vacuum leaks tonight. I will let you know what I find. Thx for the links.
Old May 11, 2005 | 03:36 PM
Tom454's Avatar
Tom454
It does have a Q-Jet, right? (not a Holley)?
Old May 12, 2005 | 10:40 AM
Dale73's Avatar
Dale73
Cruising
Ok, Problem solved. It was the timing. Its way off base. Thats for the help guy's !
To Engine Question
