4 speed rebuild
Old May 11, 2005 | 02:45 PM
dmrodco's Avatar
dmrodco
Default 4 speed rebuild
Does anyone have a source for rebuilding a 74 4 speed transmission ? Its having problems popping out of 3rd occationally .... Thanks in advance for your asssitance
Old May 11, 2005 | 03:00 PM
ImBatman's Avatar
ImBatman
Look hear: http://www.5speeds.com/ I am going to rebuild mine myself as well.
Old May 11, 2005 | 10:40 PM
oregonsharkman's Avatar
oregonsharkman
I am split between a rebuild and a 5/6 speed swap,,,...good luck guys
Old May 11, 2005 | 11:20 PM
zwede's Avatar
zwede
Popping out of gear means worn sliders and/or forks. that's of course if you made sure the linkage is adjusted correctly. The tranny has to come apart for the sliders. Since you're taking it apart anyway get a rebuild kit. Make sure the kit includes a new counter shaft (not all do). Sliders and forks are not part of a rebuild kit so you need to get those separately. The website above is a good source for parts and they are also knowledgable.
Old May 12, 2005 | 04:58 PM
Lasse's Avatar
Lasse
Did a rebuild for the first time this winter. I must say that it's pretty straight forward. I think the hardest part was to install the Muncie in the car again.... And you will need a press to take it apart.
Mine popped out of 4th gear and it was the slider that was worn. Bought a slider and rebuilt kit, that's all.
Old May 12, 2005 | 06:13 PM
comp's Avatar
comp
a good how to thread here
To 4 speed rebuild
