A/c
Old May 11, 2005 | 09:01 PM
Silver00V6Camaro's Avatar
Silver00V6Camaro
Default A/c
What is a good aftermarket ac for a 75 Coupe. It used to have air but does not have any of the componets that were with the factory air.
thanks
Old May 11, 2005 | 11:48 PM
Russ Bellinis's Avatar
Russ Bellinis
I would check out Vintage Air. I think they make systems that look stock and fit your stock dash air outlets.
Old May 12, 2005 | 09:46 AM
Silver00V6Camaro
Vintage air's web site does not list any for the corvette. I already have everything stock since my car came with aircondition. The only thing is i dont have any of the stuff to go under the hood.
Old May 12, 2005 | 01:08 PM
terry82's Avatar
terry82
i would find a salvage yard .find a wrecked 75 grab all the parts you you need and put it back to factory air .your going to spend alot of money any way you go .if its back to factory air it could help resell value .
Old May 12, 2005 | 02:29 PM
Easy Mike's Avatar
Easy Mike
Cruise-In II Veteran
Originally Posted by terry82
i would find a salvage yard .find a wrecked 75 grab all the parts you you need and put it back to factory air...
Use the parts from the salvage yard as cores for rebuilt factory parts. All the aftermarket providers carry compressors, POA valves, pulleys, etc. Get all the hoses while at the salvage yard. Any good AC shop can use the old hoses as patterns and make new hoses for you. Since you will be coming back with essentially a new system, now would be the time to convert to R-134.
To A/c
