Which harmonic damper diameter?
Old May 12, 2005 | 12:46 PM
GrandSportC3's Avatar
GrandSportC3
Cruise-In IV-V-VI-VII-VIII Veteran
St. Jude Donor '03, '06, '17
I've heared that 1 lbs of rotating mass is worth about 5 lbs of static weight at the track... For example. If you reduce your weight of your rear wheels/tires by going with lightweight wheels and wrinkle wall tires, you can save over 15 lbs each side which is a total saving of 30 lbs. Those 30 lbs are worth about 150 lbs because its rotating mass. 150 lbs is about .1 to .15 at the track.
If you are not racing, it really doesn't matter too much..
Old May 12, 2005 | 12:50 PM
comp's Avatar
comp
Old May 12, 2005 | 12:54 PM
427V8's Avatar
427V8
C6 the C5 of tomorrow
Originally Posted by gkull
snip--
GS - Dampner weight only has additional friction losses and they are much harder on bearings and the crank shaft. Just think about a 10 pound damper spinning 7000 rpm and you shift gears in nearly an instant with auto trannies and now your spinning 4500 rpm. That is allot of twist on the crank shaft.
snip---
I'm pretty sure that when the crank is twisted up with 500 ft/lbs of torque and you slam it into another gear, causing wild changes in load and torque, is a whole lot more stressfull than any rotational inertia caused by a little dampner...
Think about the load changes during a shift. 500 ft/lbs...0 ftlbs ( clutch in)...500 ft/lbs all within what 1/2 second???
As far as friction losses, What friction??? Are you talking about air friction or what?
Old May 12, 2005 | 01:18 PM
GrandSportC3
Just put a 500 lbs weight on a stick on bearings and see how much force it takes to turn it.
Then put a 5 lbs weight and try the same....and you'll feel less resistence with the 5 lbs weight...
Old May 12, 2005 | 01:28 PM
gkull's Avatar
gkull
bearing friction - - however minute. It's just like which is better internal balanced or externally. Internal has a 6 pound damper, 42 pound crank, and 11 pound aluminum flywheel = 59 pounds. external has 10 pound damper, 52 pound crank, and 30 pound steel flywheel = 92 pounds. They might make the about same power if built the same, but frictional losses and the ability to accelerate are massively different. I would not also be spinning 92 pounds to 7500 rpm in a 383 stroker two bolt small block.
Old May 12, 2005 | 01:33 PM
mandm1200's Avatar
mandm1200
You're going backwards in trying to show an example. They would be identical for all intents and purposes for this discussion. The force you would be looking to overcome is the friction of the bearing(s), same bearings= same friction. The other thing in this example is inertia which you are trying to explain as resistence.
It would take longer to get the 500 lb weight up to the same rpm as the smaller weight. The larger weight would also spin for a longer time if at the same speed when the force spinning it is removed/
Old May 12, 2005 | 01:43 PM
Buzzardz_vette's Avatar
Buzzardz_vette
My damper is 6 3/4", but I was going to put on an 8". I was told that it is better for the engine.
Old May 12, 2005 | 01:52 PM
comp's Avatar
comp
that's IT ,, inertia heck that's why the make "low mass" cranks
isn't it
Old May 12, 2005 | 02:12 PM
mandm1200's Avatar
mandm1200
How's this for an example. Let's say your engine is at 450 horsepower. You run the 1/4 mile in 11 seconds. You now hook up a hitch and pull a trailer behind it the weighs 5000lbs. Your ET is now 19 seconds. Did the horsepower of the engine change?
I realise that the damper is only a few pounds difference. By lowering the mass, it allows the engine to more quickly come up in rpm's which is something you want if racing. The sooner the rpms come up the more horsepower you are making and the faster you will go.
When I go from 55 to 60 on the highway it doesn't really matter since I am gradually accelerating anyway.
Old May 12, 2005 | 02:34 PM
comp's Avatar
comp
OK so why not put a 30 pounder on the snout of the crank,,,, because
it take's power to turn the mass,,,, if not we are all missing the boat on the energy problem
Old May 12, 2005 | 02:41 PM
mandm1200's Avatar
mandm1200
The energy consumed would be made up for when letting off the gas, making it a wash.
I'm not a damper engineer. If there was only one size and weight for all applications (grocery getter and drag car), we would not being having this discussion. There is give and take and depending on the specific application one will be better than another.
Old May 12, 2005 | 02:51 PM
comp's Avatar
comp
true ,and are you starting and stoping or at a constant all the time
if all you do is stay at the same RPM all the time i vote heavy
Old May 12, 2005 | 03:24 PM
  #33
gerry72's Avatar
gerry72
Did y'all know that the early smallblock(265 ci) only used a hub and no damper at all?
Seems once they started raising the output, a damper became a necessary evil to absorb those harmonics.
Old May 12, 2005 | 06:12 PM
  #34
comp's Avatar
comp
heavy and cheap
Old May 12, 2005 | 07:46 PM
  #35
GrandSportC3
On a engine that was internally balanced, you can even drive the car without balancer.. I have actually done that... The only thing that is different is that your idle will be a few 100 RPM higher without the balancer... If the engine is balanced well, you won't even notice that there is no balancer..
It will be more wear on the bearings, so it's not a good idea to drive too far without a balancer at all..
Old May 13, 2005 | 03:04 PM
  #36
69schemers's Avatar
69schemers
Wow, all this over a simple question. I think everyone has a good point about what they believe in. Let me add my two cents.
A larger balancer helps control the harmonics created by the rotating mass and valvetrain better then a small diameter balancer. The better the harmonics are controlled the more power can be produced. Bearing wear is evidence of this. You can have a well balanced rotating assembly but a balancer is still needed for the induced harmonics created by the valvetrain.
NASCAR has no rule on the size of the balancer only that it must be magnetic and SFI 18.1 approved and one of the HP kings Joe Gibbs Racing. They run the GM Performance Parts ATI 7.74” balancer on all their engines. If smaller was better, I would think they would all run a 6.75” balancer.
Also, we "GM Racing" has done studies in the past and have found the ATI balancer perform the best due to thier ability to be tuned to a specific RPM range
The
Old May 14, 2005 | 10:26 PM
  #37
glen242's Avatar
glen242
The
NASCAR is a whole other thing. Are you turning, constantly, over 7000RPM? From what I understand, NASCAR limits carbs to 390 CFM. Would you run a 390 CFM carb on your engine?
NASCAR is a different ballgame. I really doubt an engine from a NASCAR racer would live well on the street.
Yes, bragging rights mean a lot. I GOT NASCAR PARTS UNDER THE HOOD. I must got lots of Horsepower!!
To Which harmonic damper diameter?
Old May 14, 2005 | 11:46 PM
  #38
ddecart's Avatar
ddecart
SPARTAN
CI 3-4-5-6-8-9-10 Vet
CI-9 AutoX Winner
CI-3 Go Kart Champ
St. Jude '03-'04-'05-'06-'07-'08-'09-'10-'11
The deed is done! I went with a standard replacement Summit branded damper.. For some odd reason, this damper wasn't as wide as the one I replaced. Didn't need to use any shims at the water pump to get the pulleys in line.
Old May 15, 2005 | 07:49 AM
  #39
comp's Avatar
comp
cool did you weigh them to see if there is a difference
Old May 15, 2005 | 07:51 AM
  #40
comp's Avatar
comp
the 390cfm carbs are on the BGN cars and the Truck's to limit HP
Nextel Cup engine's can't run a roller cam ...
