Primer Paint Sealers
Old May 12, 2005 | 09:04 PM
BBtrimmer's Avatar
BBtrimmer
4th Gear
Default Primer Paint Sealers
What is the best primer sealer paint for a 71. I have sanded all the paint off the body and have some loose fiberglass strands. The last time I painted the car was in 1978. Thanks.
Old May 12, 2005 | 09:12 PM
lars's Avatar
lars
If you're down to bare 'glass, you might want to do more than just seal it in order to eliminate the 'glass show-through after painting.
You can first seal the entire car with PPG "DP" series epoxy primer/sealer (like DP-40LF). This stuff is very good, and provides an excellent adhesion base for the subsequent topcoats.
On top of this, I'd recommend shooting a polyester fill primer. Polyester primers are a lot like "gelcoat" in that they're high-building stable catalyzed coatings. This will give you a thick sanding base to cover all strand texture. Most of the major paint suppliers offer a sprayable polyester filler (it's like spraying a coat of "Bond-O" on the whole car). Once you have sprayed and blocked out the polyester, you can then use a high-build urethane fill primer like PPG's K36. This will smooth out and seal the polyester, and will allow you to do all your finish blocking and sanding for paint.
Old May 13, 2005 | 08:19 PM
BBtrimmer's Avatar
BBtrimmer
4th Gear
Thanks for all the information. It was much easier back in the day.
To Primer Paint Sealers
