alarm system??
Old May 12, 2005 | 10:06 PM
gator79's Avatar
gator79
Default alarm system??
ok I just set of the alarm system on my 1981, I just bought the car a few weeks ago and did not know it had one, all I did was lock it with the power
locks and close the door and it went off. I disarmed it by unlocking the drivers door with the key. how does the system operate and how do you arm/disarm it. thanks
Old May 12, 2005 | 10:41 PM
raydog9379's Avatar
raydog9379
Wow... yours actually works??? I wish mine did. Not really as a theft deterrant, but more as it would be 1 less thing to fix in my goal of trying to bring the car back to as close to stock as possible.
Old May 12, 2005 | 11:07 PM
Stoge's Avatar
Stoge
Originally Posted by portdawg
from the thread:
http://forums.corvetteforum.com/show...&forum_id=119]
Supposedly according to the users manual if you taker the tops off with it armed it'll alarm. At least my 79 is s'posed to. My alarms also has a mind of it's own so don't feel alone. But theoretically the only way to arm/disarm it is using a key on the outside lock of the drivers door. ONLY the drivers door controls the system. After you lock the door, either using the lock button inside or the key outside, turn the key AGAIN to the lock direction to arm. To unlock and disarm you run the key once to unlock and again to disarm. I've met with limited success, so you can take the above info for what it's worth. I had to dig the info out of my users manual. I have learned that sometimes when I think it's off, it's on and sometimes when it's on, I don't rememeber setting it.
Have fun with the experiment.
Dawg
That may explain it a bit.
To alarm system??
