Yea running a relly tight quench around .027" might help a little... so far all of the advice has been spot on, the carb spacer, KnN filter, Royal Purple all around, and electric fans, that right there will free up at least 10, probably a lot more.
If he does a fancy cam, he might as well get the plain LM1. That's about the only thing different between the two. And the savings would buy a cam...and at least 1 head!
St. Jude Donor '05-'06-'07-'08-'09-'10-'11-'12-'13-'14-'15
Les, when I dynoed mine I only had 253 RWHP and 300 FT LBS. I would love to have 300 RWHP one of these days. I was a little disappointed but I am more than happy with the performance. I have since done some tuning on the carb and timing and it feels stronger than it did when it was dynoed.
Are you running .027 quench? I did not think it was wise to run less than .035. Need input as I haven't put the heads on yet, can still get them shaved. I am looking at between .040 and .041 quench with 10.2 CR. I would like to be at about 10.5 and a little off the heads would help.
That really all depends, running a running a tight quench wont create any major problems depending on what your piston-to-wall clearance is, the smaller and tighter the piston is, the tighter the quench you can attain. Also, Depending on where your deck height on the piston is, negetive and to what extent, that has a lot to do with determining the thickness of gasket you can use. Say it was a negetive .005 deck height piston, with a .027 cometic gasket, youre looking at overall .033, which is VERY tight true, but if this is a hipo engine using high very quality parts and tight wall clearences, you should be ok. Now if this is a slightly more run of the mill sort of engine where clearences havent been checked to be that tight, then I would say moving up to a .030 or .036 might be more advisable. A lot, if not most hipo engines use a final clearence of around .040 after deck height is factored in, Ligenfelter engines run a .037 after deck height.
If 290 HP is the engine power that GM expects this engine to produce on a dynomometer then you won't be able to get any extra horsepower unless you modify the basic engine configuration.
For example, lets say you buy an Edelbrock Performer crate engine. I saw one running on the Edelbrock dyno. I think they dyno run all of their engines before delivery. The engine I observed was a 350 cubic inch engine. It had headers installed and the engine was driving its water pump. The carburetor being used was the one the engine was to be delivered with. It produced 412 HP at an rpm just a little over 6000. Obviously, if you receive this engine you won't get any extra HP unless you modify something about the engine.
...so what I'm saying is that if GM rates their engine HP similar to Edelbrock, you can't get any extra HP unless you modify the engine.
PS. That Edelbrock engine really had an awesome sound, even at any rpm. I wish I had know more about the Edelbrock crate engine quality before I bought my GM ZZ4.
I'm buying the GM Goodwrench LM1 with 290HP. I like the sound of 300 better, so what's the easiest mod for 10 more ponies?
Les
LM1 motor, $1,469 Cannot find HP
350 HO motor, $1,650 290HP. Porting/polishing the heads to the intake alone will get you 10+ hp.... cost $0.00
GM hotcam & valvesprings $350.00
1.6 roller rockers $250.00
That combo makes more HP than my street tires can handle!!!
What.. the ZZ4 doesn't have a old school muscle sound?
Well, you said .037 deck height and I assume you mean .037 quench?? Now if that is true (the .037 quench) that is a far cry from your stated .027 quench.
Not to bust A**, but are YOU running a .027 quench?
Piston side clearance is .0015 on my work in progress 383 and the DECK HEIGHT (down in the hole) is +/- .001. I am getting a calculated static CR of 10.19 and an actual quench of .040 to .041. If I can reduce the quench to .030 by a thinner gasket (still less than your .027 figure) I can pick up some on the static CR.
I do not run a .027 quench, Im talking in theory here. I dont really reccomend a .027 quench, thats exceptionally tight. Now, your piston to bore clearence is VERY tight as well, meaning you do have the option of running a tighter quench. Your deck height is also very tight. I would say that you could run a .031-.036 gasket without any problems, .027 would probably be fine as well, but at red line, I would be a little concerned.
