mechanical advance stuck?
Old May 13, 2005 | 04:33 PM
ruby76's Avatar
ruby76
From: Fairview Heights Illinois, near Saint Louis MO, STL C3 Shark
Default mechanical advance stuck?
What exactly is supposed to "move" on the mechanical advance. I took my cap and rotor off this afternoon and found that the weights move freely, but nothing else moves. Is the part that weights are attached to supposed to swivel compared to the part the rotor attaches to? I think that is where mine is stuck. How do you get this free? What would this do to how the car runs? It has terrible low end torque, the springs are really tight, even though the weights are loose as can bee, so perhaps it is stuck way advanced?
Do I keep pryingon it with screwdrivers and beating it with a hammer to get it loose?
Jeremy
Old May 13, 2005 | 04:40 PM
lars's Avatar
lars
The weights, when they move, should apply force against the conter cam and move the center cam relative to the outer cam plate. If the weights are loose but are not moving the one component relative to the other, the unit is seized up. This is very common on the HEI distributors. The fix is to yank the distributor out, disassemble it, clean up the parts with some ScotchBrite, lube it and put it back together. Very easy process. While you're in there, replace the vacuum advance control unit with NAPA part number VC1838 and install a soft set of advance springs.
Old May 13, 2005 | 04:47 PM
ruby76's Avatar
ruby76
thanks for the info!!!
Do you ever have to replace the little module in there?
Old May 13, 2005 | 05:16 PM
ruby76's Avatar
ruby76
NAPA website says VC1838 isn't a valid part number, but they do have VC1836 - is that the same one?
Old May 13, 2005 | 05:32 PM
comp's Avatar
comp
can you call a store ????
Old May 13, 2005 | 05:40 PM
fl_rider's Avatar
fl_rider
Default Interesting article about Vacuum Advance
My curiosity was piqued so I went looking around and found this thread on a Camaro board. There is a listing of Echlin Vacuum Advance part numbers.
http://www.nastyz28.com/ubb/Forum8/HTML/009276.html
Old May 13, 2005 | 05:41 PM
fl_rider's Avatar
fl_rider
Default This was in the thread listed above
VC1838 AR12 1975 350 Buick 7-9 7 @ 10-12
Old May 13, 2005 | 05:59 PM
comp's Avatar
comp
Hmmmmmm
Old May 13, 2005 | 06:02 PM
fl_rider's Avatar
fl_rider
Default Info about the 1838
The following listing (HEI) is as follows: The first four part number listings are the 4 numbers that are most commonly used in a Chevrolet performance application. The “AR12” can is the most versatile and user-friendly unit for a good performance street engine. The AR 15 and AR23 are almost identical, with only slight variations in their “start-stop” specs. The “AR31” can is the HEI equivalent to the “B28” Hi-Perf can used on the early engines: The advance comes in very quick on this unit – too quick for many performance engines. Do not use this very quick unit unless you have a cam/engine combination that really needs an advance like this. It can be used as a tuning aid for problem engines that do not respond well to other timing combinations, and can be successfully used in applications where direct manifold vacuum is applied to the can (see paragraph and discussion on this above)
After this, the listing is by Echlin part number. All GM HEI vacuum advance units are interchangeable, so you can use a Cadillac or GMC Truck unit on your Vette, if that’s what you want to do.
HEI Distributors:
P/N ID# Application Starts @ “Hg Max Adv
(Distr. Degrees @ “Hg.)
Old May 13, 2005 | 11:44 PM
LiveandLetDrive's Avatar
LiveandLetDrive
I've had this happen twice, the second time I just bought a new dist. for $100.
-Chris
Old May 14, 2005 | 11:03 AM
ruby76's Avatar
ruby76
You're right, I called and they have it, just not on the website....
So - would this explain my crappy low end power? because it's too advanced because it's stuck open?
Old May 16, 2005 | 03:57 PM
ruby76's Avatar
ruby76
Ttt
Old May 16, 2005 | 04:08 PM
bobs77vet's Avatar
bobs77vet
From: Arlington Va Current ride 04 vert, previous vettes: 69 vert, 77 resto mod
perhaps you are looking at this wrong....what if it was stuck open and then the car just wasn't running right...hard to start etc.....some one looks at the timing and says "no wonder its running like crap the timing is way off" so they retard it to where it should be at idle....now its ok at idle but there is no mechanical advance....the advance curve is flat giving crappy low end power
Old May 16, 2005 | 05:24 PM
comp's Avatar
comp
yep one of my truck's was that way,,, and i stuck the Mr. Gasket kit in there now i need to change it
Old May 17, 2005 | 08:38 AM
ruby76's Avatar
ruby76
Right, that is what I meant, becuase it was advanced, the timing was set to speck (with distributer stuck in advanced position) thus giving ok timing at /near idle, but no mech advance with higher rpms. Im going to try for a good old test drive again this evening. I drove with the wife Sunday evening after freeing this up and I could tell a difference, but I want to see if she'll smoke a little rubber now. couldn't do it before even with popping the clutch
Old May 17, 2005 | 09:31 AM
comp's Avatar
comp
cool, let us know
Old May 18, 2005 | 08:34 AM
ruby76's Avatar
ruby76
Default Woooowwww!!!!!!
Runs like a scalded cat!!!! - heard that the other day and thought it was funny, yet descriptive. That explains the difference in my "lazy dog" that it was with the mech advance stuck. I've heard Lars say you need at least a 10 hp increase to "feel" a difference, I'd say this was a 20 hp increase over the messed up mech advance. I can't wait to get my curve kit in!!!!!!!!!
My advice to ANYONE complaining about not enough power - and I don't mean like "i want 500 HP" but not enough power even for a stock 350, to have a look at your mechanical advance and verify that it is in fact working!!!!!!!!!!!
To mechanical advance stuck?
Old May 18, 2005 | 10:50 AM
A2Shark's Avatar
A2Shark
This was EXACTLY my experience. While I was at it, I installed an Excel Super Coil, new plugs & wires, and the recurve kit. An amazing difference in performance!
Old May 18, 2005 | 10:57 AM
danno12345's Avatar
danno12345
Me too. I couldn't believe how much difference it made when I unstuck mine!
When I took it out to test it, I'm pretty sure I looked like this smiley -->
Now I just need to figure out how to get the starter to crank again...
Have Fun!
Dan
Old May 18, 2005 | 10:53 PM
carl a's Avatar
carl a
it was''scalded dog'' i used when lars set up my 73 at the tuning tour,,,some one else added the cat instead of dog
