Need piston ring help
Old May 14, 2005 | 11:36 PM
Bullyj's Avatar
Bullyj
Default Need piston ring help
What my problem is, I bought the Eagle 383 rotating assembly and it came with perfect circle rings and I'm unsure which one is the top ring. There is a dark one which I believe is the moly coated one and a lighter one. I believe the dark one should go on top but I'm unsure and I paid what I believe to be a fair amount for it not to mention the extra work it would cost me so I want to get it right. Thanks in advance for any help.
Old May 15, 2005 | 08:00 AM
GDaina's Avatar
GDaina
The rings come in a box....the rings are packed in containers and are marked top ring, middle ring.
Old May 15, 2005 | 08:05 AM
comp's Avatar
comp
should have been if not you need to contact them
Old May 15, 2005 | 11:59 AM
Bullyj's Avatar
Bullyj
Actually they came in one box with 3 compartments after read your replys I checked inside the compartments still nothing. Then I saw it marked on the tabs that fold under the lid. Thanks guys, I'm feeling about stupid right now
Old May 15, 2005 | 09:38 PM
adam's Avatar
adam
So which one is which...
Old May 15, 2005 | 09:44 PM
mandm1200's Avatar
mandm1200
Don't feel bad, I did the same thing.
Old May 15, 2005 | 09:52 PM
87bob's Avatar
87bob
Veteran: Coast Guard
Hey better to feel stupid than not to ask and to be stupid
Old May 16, 2005 | 02:57 PM
LemansBlue68's Avatar
LemansBlue68
Make sure you get the rings oriented in the right direction when you install them!!
Old May 16, 2005 | 03:10 PM
comp's Avatar
comp
For Sure
To Need piston ring help
