From: Exiled to Richmond, VA - Finally sold my house in Murfreesboro, TN ?? Corner of "Bumf*&k and 'You've got a purdy mouth'."
CI 6-7-8 Veteran
CI-VIII Burnout Champ
St. Jude Donor '06-'10, '13
Originally Posted by bobs77vet
seems like maybe you should take a break and come back to it tomorrow....i would not grind the u joint....play with it some more
problem is that I am leaving for Bowling Green on the 21st and with my job I could get called out of town for work on Monday and not get home till the night of the 20th.
I will work more with it tonight when the temperature drops back below 100 degrees outside, and I am sure I will be on the phone with Speed Direct first thing in the morning.
Bseery
What you want is that column aligned as straight as possible with the input shaft on the rack. Move the rack in towards the engine or back towards the fender, whatever it takes to get it straight and then get the column back as far as possible. Take as much curve as you can out of the u-joints even if you have to cut some off the column. I cut about a 1/2 inch off my column with a small cut-off tool. You also have to play with spline alignment to get the steering wheel centered.
You WILL like it when you get it aligned !!
I can't post a picture as I have no camera but my end nut only has 3-4 threads left showing
People with the production steering system sometimes have problems with their steering column shaft being collapsed and therefore being too short to reach the flex coupling.
You guys with the Steeroids system just have the opposite problem.
Don't shorten the lower steering column shaft by cutting it off! Just tap on the steering column shaft until it starts to collapse back into steering column. You can probably shorten it 4 inches or so. Shortening it by collapsing the lower steering shaft will not cause any safety problems.
Caution: This only works on 1967 and later columns. Anybody with a C2 (except 1967) has a one piece solid steering column shaft.
Keep at it Bryan, I have been working with mine this week too. It takes some fooling with but I have got it right twice, unfortunately I didn't stop while I was ahead. I have some minor binding right now but I'm driving it. It is well worth the effort. Got to luv the "new feel".
CI 6-7-8 Veteran
Well, I talked to Eric at SpeedDirect's main location. He had me check the following.
Make sure that the lower U-joint is on to the pinion shaft to the point that the pinion shaft is even with the inside of the u-joint opening. On mine the pinion shaft actually protrudes about 1/16th of an inch further. I did loosen this and move that u-joint up and down and it makes a MAJOR change in the entire alignment of the shaft.
2nd. He had me adjust the center bearing support. I had it pulled as far forward as possible. He had me change this to being adjusted about 1/2 way.
So far, from what I can tell by turning it manually with no power assist (don't have fluid in the car) that this adjustment has taken care of my binding. I will know later tonight.
Chad -- are you going to either of the events this weekend? There is a pizza dinner / get together Friday night and a cruise to Show Low Saturday for lunch. Let me know if your coming or interested.
I mistated my description of shortening the steering column shaft in my posting this morning. You really should just press straight against the end of the shaft rather than tapping or banging on it. Sharp blows could damage the bearing in the lower end or the bearings in the column head. You want a slow consistant press load to move the shaft up into the steering column.
I'm seriously considering making the run Sat. Sounds like it might be fun and a good chance to get a little wheel time too. You came over to my house about 3yrs ago when I installed my fans, don't know if you remember or not.
Um Gene wasn't talking about his steering shaft, the dirty old man...
BUT, that's just the whole damn point,,....I Wuzz talking about my steering shaft, and I have been known to bend hell out of it, break my bearings, and screw up the thrust alignment....
