Removing composite rear spring
Old May 14, 2005 | 11:48 PM
colorado1967's Avatar
colorado1967
Default Removing composite rear spring
As always, greatly appreciate the forum members suggestions!
I am removing composite rear spring and do not see a good spot to place a c-clamp? I read you can use wood to protect the finish but it would seam the clamp would not have much to hold on to.
The metal end does not really provide room for a clamp and still be able to remove the bolt. Suggestions on where / how to clamp to stop the jack from possibly slipping appreciated.
Old May 15, 2005 | 12:24 AM
lostpatrolman's Avatar
lostpatrolman
I put the car up in the air, then grab the very end of the spring with the jack. It doesnt take much pressure to take the load off the bolt.
Old May 15, 2005 | 09:05 AM
brooksman9's Avatar
brooksman9
St. Jude Contributor
https://www.corvetteforum.com/techti...D=75&TopicID=3
Old May 15, 2005 | 02:03 PM
Burgundy 69's Avatar
Burgundy 69
I just replaced a 7-leaf steel spring with a 9-leaf steel spring (correct for my car) and found the task pretty straight forward. I assume a composite spring would respond like a steel spring when being removed and installed.
I cut a 2 x 4 to approximately half the length of the spring, (from the outside edge of the spring mounting bracket to several inches from the spring bolt hole at the end of the spring) and using my floor jack, I raised the far end of the spring enough to remove the bolts and hardware. The 2 x 4 wedged itself up against the bracket and could not slip.
After installing the new spring at the differential, I repeated the process. Everything lined up perfectly and the bolts were in before I knew it. BTW, I used liberal amounts of copper "never seize" on all bolts and between the new poly bushings. So far no squeeking from the rear and the nut can be turned by hand.
I had my C-clamp ready for use but never needed it. Of course, your mileage may vary. Good luck.
Mark
Old May 15, 2005 | 05:42 PM
68/70Vette's Avatar
68/70Vette
My experience also. I've taken my composite spring off probably at least two times. I just place the tip of the floor jack lifting disk under the metal sheathed extreme end of the spring. It takes only a little lift to take pressure off.
Taking the composite spring off and on is no-where the hassle of the steel spring.
Old May 15, 2005 | 09:36 PM
Oldguard 7's Avatar
Oldguard 7
You can unload your spring without using a jack. take a 2x4 piece of wood and place it on the strut rod and use it as a prybar to take pressure off the spring. Do the reverse to load the spring. Got the tip from BAIRS corvette 100 point inspection video.
Old May 15, 2005 | 11:47 PM
colorado1967
Thank you all for the great tips and will get started in a couple of days.
Steven
Old May 16, 2005 | 10:10 AM
Van Steel's Avatar
Van Steel
Premium Supporting Vendor
I use vice grips and place them on the inner part of the metal end caps. Than use a jack and jack up right on the vice grips.
To Removing composite rear spring
