Distributor questions
Old May 16, 2005 | 08:34 AM
vette70's Avatar
vette70
Default Distributor questions
My old stock distributor giving problems. Looking to upgrade on 1970 350/350. Any suggestions.
A friend suggest Mallory Unilite Distributors
http://store.summitracing.com/defaul...mpare.asp?LB=1
Old May 16, 2005 | 08:46 AM
ruby76's Avatar
ruby76
From: Fairview Heights Illinois, near Saint Louis MO, STL C3 Shark
I never make any friends on this forum, cause I always suggest stock parts. I'd go to a junkyard and get a good used GM HEI. Then follow Lars' instructions on how to re-curve with springs/weights - maybe a better coil if your interested. I'll never see much RPM above 5 anyway, so stock coil is good for me.
Old May 16, 2005 | 09:21 AM
OldSchool's Avatar
OldSchool
Default Distributor
Don't forget about your tach being cable driven by the distrib...
This is about the cheapest I've seen..
http://www.hotrodsusa.com/store/product2158.html
Old May 16, 2005 | 09:38 AM
comp's Avatar
comp
HEI is a good pick, i think i read somewhere a company has one with tack drive,,,
Old May 16, 2005 | 11:03 AM
vette70's Avatar
vette70
Default shipping cost
Look at the web site for the CHEVROLET HEI with Mechanical Tach Drive you suggested
They want $91.34 for shipping, wondering if the guy is going to bring it directly to my house and put it in.
Doesn't this seem high for shipping
Old May 16, 2005 | 11:06 AM
Gordonm's Avatar
Gordonm
What is wrong with your old dist. A properly setup stock dist will work as well as any of the others out there. I am using my stock dist to fire a Crane HI6 box and it has proven very good to 7000 rpm. The reasong I went with CD ignition is I wanted a rev limiter and a little hotter spark. NO HP will be gained by going to an aftermarket dist. You can rebuild your stock one and it will work fine.
Old May 16, 2005 | 11:20 AM
vette70's Avatar
vette70
Default How it started.
It all started the other day retured home let of gas to pull into drive way and engine died, noticed tack quit, and would run well at all. Wouldn't idel, no power at low rpm and coughs and will backfire if goose it to fast a low rpm.
Unhooked mech. tack cable and it will spin the tack needle some assume problem in tack with stripped gear. No knowing but assumed it might also be affecting vacum advance causing carb problems.
Others suggest vacum leak, etc. Just thought if going to trouble of tackling problem a new dist. might be the better way to go, since I just bought the Vette and have little knowledge of how old the dist. is.
I know just enough to be dangerous when it comes to ignitions problems.
Old May 16, 2005 | 11:23 AM
Garys 68's Avatar
Garys 68
Diagnose the actual problem. You can throw A LOT of money at the car and still not fix it.
Gary
Old May 16, 2005 | 11:24 AM
OldSchool's Avatar
OldSchool
Do you live in Hong Kong? LOL..That's the shipping there..
I hit he dropdown and it was $10.18 UPS ground to my zip???
Old May 16, 2005 | 11:33 AM
vette70's Avatar
vette70
Default my mistake
you are right , I didn't see the box was on Asia and clicked recalculate.
Much better price 20 bucks, which is more like it.
Old May 16, 2005 | 11:35 AM
kdf1986's Avatar
kdf1986
If you change from the mechanical tach to a HEI unit, then you will also have to replace the tachometer to match. Thats another added expense, and a reason to try and rebuild your current one.
kdf
Old May 16, 2005 | 11:39 AM
vette70's Avatar
vette70
Default mech tack
CHEVROLET HEI with Mechanical Tach Drive, I assumed this model would work with in dash factory tach, was I wrong to assume this.
Old May 16, 2005 | 12:11 PM
Gordonm's Avatar
Gordonm
That dist. will work with the factory mech. tach
Old May 16, 2005 | 12:17 PM
OldSchool's Avatar
OldSchool
kdf
That's true with a GM HEI, but the one he is looking at is a tach drive HEI.. This is the way to go..
To Distributor questions
