anyone recognize this
Old May 18, 2005 | 10:41 PM
panchop's Avatar
panchop
Default anyone recognize this
looking to find a lugnut key for this . any idea where to start. don't want to slip and screw up the wheel grinding it down.
Old May 18, 2005 | 10:47 PM
bobs77vet's Avatar
bobs77vet
From: Arlington Va Current ride 04 vert, previous vettes: 69 vert, 77 resto mod
old school trick is to weld a nut on it
Old May 18, 2005 | 10:54 PM
corvettecris's Avatar
corvettecris
At my old shop, when we couldn't find a key, we got a nice, thick socket and hammered it onto the nut, then took it off. Worked pretty often, but ruins the socket. Cheaper than a set of wheels, I guess. Just a last resort idea....
edit:
Like the above idea better!
Old May 18, 2005 | 11:05 PM
BSeery's Avatar
BSeery
From: Exiled to Richmond, VA - Finally sold my house in Murfreesboro, TN ?? Corner of "Bumf*&k and 'You've got a purdy mouth'."
CI 6-7-8 Veteran
CI-VIII Burnout Champ
St. Jude Donor '06-'10, '13
most tire shops have a lock remover. It's like pounding a socket on. It has teeth inside the grip the outside of the lock nut and removes it.
Go to a good wheel and tire shop and ask them to remove it and buy some new locks.
EDIT: I noticed your in Mesa Arizona. Try Discount Tires, they should be able to help.
Also, check out http://ArizonaVette.net - the web site for the local members of the Corvette Forum. Hope to see you at some of our upcoming events.
Old May 19, 2005 | 12:34 AM
SkunkApe's Avatar
SkunkApe
Craftsman Bolt Out set:
Old May 19, 2005 | 09:15 AM
corvettecris
This might work too:
http://gator-grip.com/big_gripper.htm
To anyone recognize this
