Hydraulic Clutch Conversion
Old May 22, 2005 | 10:27 AM
DJ Dep's Avatar
DJ Dep
St. Jude Donor '05-'07
I wind up my mechanical Timex watch every day and it doesn't lose a second of time. I go to the ICE BOX for a soda pop that is in a GLASS BOTTLE and I use a bottle opener to get the cap off. I have a MECHANICAL dual point distributor for use on my engine.
I will ADD LEAD to the gas because the compression ratio will be 12-1 or higher. I only watch drag racing on TV and most of the rest of the time I listen to an AM radio. Oh yeah...my computer is a Commodore 64
And the only holes I like are in the swiss cheese that are on my ham sammiches.
Dep
Old May 22, 2005 | 11:55 AM
BerniesVette's Avatar
BerniesVette
Dep,
You are Da Man! You try to keep us straight but there are too many of us spoiled by the good life. I don't even wear a watch anymore, just look at my cell phone.
But we've stopped talking about cars. I still think a Hyd. clutch is the way to go, unless you are drag racing, then you really have to get high tech to win with the big boys. But it is a sport that has a nich for every level of competition.
You guys continue to do what you like to do. I just rode 10 miles, going to finish my rear suspension rebuild today, bleed the brakes (stock), used rubber bushings (stock), kept my 9 leaf spring, and will put my stock tires and wheels on and get it to the alignment shop. Somewhere in all this I will trim and mow.
Enjoy what is left of the weekend!
Bernie
Old May 24, 2005 | 01:11 AM
71coupe's Avatar
71coupe
Originally Posted by 71coupe
Why are you converting to hyd?
Originally Posted by norvalwilhelm
A better question is why not???? It is a simple bolt in, no worry about cross shafts or mounting points, no fuss. Doesn't interfer with headers in any way. You can go to the auto parts store, any store and buy the parts brand new cheap enough.
Why would I want the old mechanical linkage that could possibley bind under hard engine torque??
Go modern, go hydraulic.
I can understand if he was converting to a late model GM 5-speed that already uses a hyd system, then you would need it...but with a hyd clutch you end up with an "artificial" feel IMO. For clearance issues I'd fix the exhaust. BTW, I'm planning on a hyd clutch connersion in my '59 Chev truck only due to the crossmember being removed to make room for an BB Olds (The crossmember had all the clutch mechanical linkage on it). Getting tired of the auto.
