Spark Plug for '79 ... Std. AC or Rapidfire?
Old May 20, 2005 | 03:47 PM
Tom T's Avatar
Tom T
Default Spark Plug for '79 ... Std. AC or Rapidfire?
currently have Rapidfire.. is it worth the extra $ or just go w/the Std. AC Plug? I have a stock L48 '79
thanks... TGIF
Old May 20, 2005 | 04:00 PM
marshrat99's Avatar
marshrat99
IMO the standard plugs are all that you'll need under most circumstances. I'm sure you could use the $ you'll save elsewhere.
Old May 21, 2005 | 09:38 AM
bigvette1's Avatar
bigvette1
Default Plugs
I used the rapid fire for a BBC and did not find any real gain in performance. I did think the idle was a bit smoother with the rapid fires. Are they worth the extra $$'s - that is a decision on how often you change plugs.
Old May 21, 2005 | 09:43 AM
73conv's Avatar
73conv
I have used the expensive plugs, but went back to AC and didn't notice a difference.
Old May 21, 2005 | 10:04 AM
gkull's Avatar
gkull
If your heads are the short reach tappered plug. Get Bosch Platinum +4 They really worked for me.
Oh the part number is 4449 it's the four tip
Old May 21, 2005 | 11:39 AM
78pacer's Avatar
78pacer
Bosch are excellent plugs. They have a very true heat range. I run either Bosch or A.C. and have had good luck. Bag Champions, the plugs have a very inconcistant heat range.
Mike
Old May 22, 2005 | 10:04 AM
71redskin's Avatar
71redskin
Default plugs on '79
i was just with the master and recall hearing him say that he went somewhere that had a way to test spark plugs by checking them under variuos compressions to see which ones lost their spark the quickest...his observations were that the new platinum tipped plugs lost their spark consistently at lower pressures than the old tried and true champions an ac delco's...
Old May 22, 2005 | 10:25 PM
Tom T's Avatar
Tom T
thanks for replies everyone... think I'm gonna stick w/the std. AC's
Old May 22, 2005 | 11:37 PM
Glassbowtie77's Avatar
Glassbowtie77
I find that the stock AC Delco's run the best in my car, no need for anything fancy.
To Spark Plug for '79 ... Std. AC or Rapidfire?
