Problems with braking and turning
Old May 23, 2005 | 09:29 PM
  #61
redvetracr's Avatar
redvetracr
[QUOTE=norvalwilhe Real race cars don't run proportioning valves. They limit how fast the rear brakes come off too.[/QUOTE]
In a sence they DO...they run a balance bar that limits the amount of force the pedal applies to the rear master, they also run different size masters front & rear.
...redvetracr
Old May 23, 2005 | 09:35 PM
  #62
norvalwilhelm's Avatar
norvalwilhelm
Originally Posted by redvetracr
They run hot because they tape the grill openings for DOWNFORCE!!
Also they ran more spark advance and leaner. They didn't have to last just make power. That practice was outlawed.
Old May 23, 2005 | 09:37 PM
  #63
norvalwilhelm
[QUOTE=redvetracr]
Originally Posted by norvalwilhe Real race cars don't run proportioning valves. They limit how fast the rear brakes come off too.[/QUOTE
...redvetracr
That's the way Roger does his race cars. A balance bar to limit pedal force to the rear.
With my 14 inch rotors and 1 7/8 calipers on the front and 12 inch rear with 1 3/8th caliper pistons I figure I already have alot of bias built into the system.
Old May 23, 2005 | 09:57 PM
  #64
turtlevette's Avatar
turtlevette
St. Jude Donor '03,'11
you're throwing the bias out of whack. With the same clamping force 2" further out your getting 14/12 = 1.17 times more torque in the front which could cause the front to dive excessively.
Old May 23, 2005 | 11:24 PM
  #65
mrvette's Avatar
mrvette
You know, I thought of that when Norval was talking of his new rotors last winter?...well I thought of the radius....~6" vs ~7"....that is nearly 15% differance in stopping the rotation right there....if that don't make the rear squirrely I dunno what would.....
forgot about that earlier, or would have said it....
oh well, Norv needs another project....eh ???
GENE
Old May 24, 2005 | 05:06 PM
  #66
joe73vette's Avatar
joe73vette
You certainly do: The bigger calipers make 1.86 times more clamping force, and the larger rotors (assuming the center of the force is applied 1" from the edge) give 1.2 times the lever arm. This means you are applying 2.23 times the braking force to the front wheels. Or in other words, 69% of your braking force comes from the front, 31% from the rear. I guess that is about right because there is more weight on the fronts. Anybody read any race car setup books?
Also, from my experience at race driving schools, you really shouldn't brake after your turn-in point, except in special cases. The tires can only do a limited amount of work at any given time. It's called a friction circle or G-circle or something like that.
Joe
Old May 24, 2005 | 06:52 PM
  #67
CrossedFlags77's Avatar
CrossedFlags77
Its a friction circle.
Old May 24, 2005 | 07:06 PM
  #68
C4kid94's Avatar
C4kid94
norval, we ALL know it doesn`t cost $4K to flow a set of heads and if I remember correctly YOU ported those heads yourself.
If it`s a "known fact" then why does EVERY professional racing series from NASCAR to NHRA use ALUMINUM HEADS ????
...redvetracr
i agree aluminum are better and it wont cost 4k. ill describe a 4k job that super modifieds run. the port in out some much they go in to the bolt holes and ohter spots and have to epoxy the holes. And i dont even think that cost 4k.
Old May 24, 2005 | 07:09 PM
  #69
C4kid94's Avatar
C4kid94
No the heads were ported before I bought them then I added the best valve guides I could get, I also bought severe duty valves. I worked on the ports then had Dave Rayborne do them fixing any turbulance I had.
I went to the speed shop and I need a Brodix head in the $3800 range to flow 348 cfm at 600 lifts. That is what the heads would cost me to replace what I have now.
As for aluminum vs cast iron I am not a racer. I just like to drive fast. I will not bother switching to aluminum unless I get a helloff adeal on a set better then I have now.
I also doesn't handle like a cadillac, no cady can follow me around a right hand turn onto another street at 60 mph.
Only 348 cfm The sb2.2 heads im going to get flow 400 cfm and there sb. but they do cost 14k new. but i have connections and can get them for 4k with matched and ported intake.
Old May 24, 2005 | 09:32 PM
  #70
DJ Dep's Avatar
DJ Dep
St. Jude Donor '05-'07
Will one of you rich guys adopt me?
Dep
Old May 24, 2005 | 09:42 PM
  #71
lostpatrolman's Avatar
lostpatrolman
me to!
Old May 25, 2005 | 05:09 AM
  #72
Twin_Turbo's Avatar
Twin_Turbo
I'm interested about that engine combo. It's great if you can get those heads with the corresponding intake and know what they were ported for. Most of the sets on ebay are for restrictor plate racing or are rejects that didn't work, without the intake manifold most of them are useless as the intake has to match the port design in the head for max. efficiency, the cfm isn't the only thing that matters. There's a reason why those heads are relativly cheap on ebaymotors, they were designed for a very specific application (or if they're rejects they're worthless on almost anything) and you may not get what you expected. It's the same thign with a lot o stuff on ebaymotors, especially the cup parts...buyers beware. Same goes for the SB2 heads, they are similar (but different) to the later SB2.2 head but the main difference is in the compression ratio, those heads are for very high CR and they were dropped when nascar lowered the CR rules, the parts for those heads are almost impossible to get, the current SB2.2 head components are widely available but expensive.
When using a flat tappet cam you also need a block w/ revised lifter bore angles & spacing because of the spread intake port and intake rockers, offset lifters won't get you enough offset for use w/ a flat tappet cam.
Old May 25, 2005 | 08:30 AM
  #73
norvalwilhelm
You guys should check out the prices in our speed shops. The Brodex heads might be $2100 american but up here that translates into $3800 from our speed shop. I have the Brodex catalogue and to get heads from them that match my honest flow figures I need to spend that much. Some time when I have nothing left to do I might look for another set.
Last winter I spent about $6000 on the modifations I made. I try to limit myself each year to about $5000. The year I went and converted to the blower I spend $9500 on the conversion.
When do you say the hell with it? It is only something to occupy my winter hours. I don't want to throw too much money at it all at once.
If I came across a really good deal on a big set of heads I would take it. I remember MountainMotor offered me a really good set at a good price. Maybe next winter.
Anyone see American HOt rod last night and the 1500 horse small block vet they built???
Old May 25, 2005 | 08:42 AM
  #74
427V8's Avatar
427V8
C6 the C5 of tomorrow
C5's and C6's have a lot more front Bias than our cars do...
Old May 25, 2005 | 09:33 AM
  #75
turtlevette
hard to believe that.
With my dynalites on front that slightly reduced front brake torque i really like the way it stops now with less nose dive.
Old May 25, 2005 | 10:02 AM
  #76
gkull's Avatar
gkull
which tire or tires locks up first and what is the maximum speed that you have been able to lock up a tire. the maximum speed really is a function of two things. How good your brakes are raises the speed and how good your tires are lowers the speed.
I wasn't going to get in on the science of iron and aluminum. But modern thermal barrier coating on the chambers, valves, and ports keep the energy in the cylinder and not going out to your radiator. That's why I have sent my heads and parts to www.swaintech.com
Old May 25, 2005 | 11:43 AM
  #77
turtlevette
i think i can lock the tires at ANY speed but have not tried it at speeds over 60.....yet.
I would not feel comfortable with a system that wouldn't lock at any speed.
To Problems with braking and turning
Old May 25, 2005 | 05:09 PM
  #78
Yellow73SB's Avatar
Yellow73SB
St. Jude Donor '07
Ihave a link for this place who checks all the stuff before they sell. if you want it let me know.I can build a motor but i get confused with the names what is ma flat tappet cam again?
Old May 25, 2005 | 05:11 PM
  #79
Twin_Turbo's Avatar
Twin_Turbo
is it muscle motorsports? a flat tappet cam is a cam for use w/ flat tappet lifters..hmm..how to explain..err not rollers the profiles are different (less extreme) than the rollers and the lifters spin which makes that the pushrod has to sit in the middle, rollers don't spin and therefore they can use offset pushrods.
Old May 25, 2005 | 08:52 PM
  #80
norvalwilhelm
If you take head flow numbers you have to subtract intake flow restrictions and this can quickly equal 20% so your 400 cfm heads could quickly loose 80cfm or flow 320cfm.
All intakes run between 15 and 25% lose.
With a blower putting out 12 psi my flow actually goes up alot. I wish I could figure out how much but my heads were flowed with 28 inches of vacuum, I would love to know the flow numbers with boost.
