Electical Problem " HELP "
Old May 22, 2005 | 07:50 PM
The Corvette Kid's Avatar
The Corvette Kid
Default Electical Problem " HELP "
Today was a beautiful day in Pennsylvania to go for a ride in my 78 Corvette. About an hour in to the ride I noticed my GEN light flashing intermittently,and when it flashed the amp gauge and the tachometer also went crazy. After a little while the GEN light stayed on permanently and the tachometer and amp gauge were both dead. When I got home I put a volt meter on the battery, it showed 12.7 volts,and with the engine running it was charging 14.3 volts.I then decided to try with headlights on, it still charged but the warning buzzer stayed on steady. Also the power windows won't work. One more thing, when I turn on the headlights the oil pressure gauge goes to zero. If anyone can help me with this problem I would really appreciate it. Thanks, Bob
Old May 22, 2005 | 08:22 PM
any4xx's Avatar
any4xx
I know this sounds like a simple answer, but that's because it is...
Check EVERY ground connection first. Start with the battery then go everywhere you can find a wire under a screw. 99.9% of the time that's the problem when seemingly-unrelated things all start going weird at once.
Old May 22, 2005 | 10:23 PM
Jack71's Avatar
Jack71
I would make sure to have a quick disconnect installed on the battery. Check to see if you blew any fuses.
To Electical Problem " HELP "
