VACUM Question
Old May 23, 2005 | 08:33 PM
buckethead's Avatar
buckethead
Default VACUM Question
checking the vacum on my car tonight and this is what i got 13 at idle, running rpms up to 2500 it went up to 19. the fluctuation was about 1 above and below the numbers above after letting off gas vacum jumped to about 25 and then dropped back to 13. engine runs loopy at idle but when running down the road it run fine. i read that at idle it should register between 17 and 22 any ideas of problem?
Old May 23, 2005 | 11:17 PM
vettepilot68's Avatar
vettepilot68
It really depends on the cam. ie, more radical, the lower the vaccum at idle.
