Thanks,
Are there any more Corvette specialty Parts houses out there that I am not familiar with? - I know the bigger ones I guess. Have not heard of Zip before.
You definitely need the spring liners from Zip. Also, you might want to have the spring re-arched at a local spring shop to get it back in shape for the correct ride height...
As far as speciality houses, I was gonna list a few, but didn't want to leave out anyone - I just did an quick 'advanced search' at Google.com for 'corvette parts' and it returned over 700,000 pages!
Sincerely,
Alan G.
Vette Brakes & Products, Inc.
Saint Petersburg, FL
I was not gonna have it re-arched. The stance is good and even and the ride height is good. The only reason that it is out of the car is the diff work that I have going on. I figured that since it was out, I would redo it with new liners. I looked at the Zip website and only could find the ones for '63 to '74 (did not go past '74). The set for '63 to '74 are too small for my spring. So I called Dan at Van Steel and tried to see if he had any. He had no luck locating them.
I figured that I could possible make my own out of truck inner-tube material or go to our rubber supply house and get a sheet of rubber and then cut them to the correct dimensions myself. I figure I need 1/8" thick material (uncompressed) - couple of feet long and 2.5" wide.
Slap that bad boy in there and give it some whatfor.
