I have been following Jim Shea's wiring diagram as well as my AIM diagram and am having a problem matching up the last 3 wires on the harmonica connector to the 3 wires remaining on the harness.
According to the paper:
Switch Harness to Body Harness
G Black 18 gage to Black 20 gage
F Light Green 20 gage to Pink/Black 20 gage
E Tan 20 gage to Black 20 gage
I have these remaining that I need to match up. Allothers were correctly corresponding with Jim's paper.
Switch Harness
G Black
F Pink
E Black
Body Harness
Black
Pink W\Black stripe
Black with what looks to be a yellow stripe.
I do not have a light green or a tan wire on the T\S switch as is referenced in the paper.
one black lead should go to the horn, the other to the Left Hand Door Jamb & Key warning Switch.
The pink wire, I believe should be a Pink with dark blue & black stripes and should go through the bulk head connector to the Horn & Key Warning Buzzer Relay.
There isn't a Tan or Light Green wire in that harness
